Thread: Airbag light - suspect coding is problem
  1. Question Airbag light - suspect coding is problem
    Aug 2014
    Newport, S Wales
    Hi, I recently purchased a VW Passat b6, it had the airbags deployed. Bit of a challenge given i dont know much about the SRS system. Ive worked on Ford vans and replaced airbags in these in the past, but to reset them it was simple, just whipping the battery connection off for a few mins. VWs a whole different story.
    I have replaced the dash and airbags. I also replaced the module. I made sure all the part numbers were the same.
    Since this i now have the airbag warning light on.
    I have tried resetting with a scanner but it comes straight back on.
    Fault codes are as follows:
    00598 - Airbag ignition circuit 1 - passenger side N131
    01224 - Control Module doesn't match vehicle
    01228 - airbag cut off switch for passenger side (E224)
    Are they 3 faults or is it one, with all 3 being brought on by the module error?
    Also is it simpler for me to send the original module, that deployed the airbags, to be repaired. Or get the new one i fitted re-coded???
    Any help will be appreciated!
  2. Re: Airbag light - suspect coding is problem
    Norfolk
    The air bag module must be coded to the car. You need vcds, A generic scanner can't do it.
  3. Re: Airbag light - suspect coding is problem
    Feb 2013
    Gloucester
    57 Post(s)
    Were your new airbag parts new or second hand? They may be coded to the other vehicle if its the latter?
    Sent from my iPad using Tapatalk HD
  4. Re: Airbag light - suspect coding is problem
    Aug 2014
    Newport, S Wales
    Yup thought this was the case. Have sent original module away to be repaired. £30 not bad for this. Lets hope it works.
    Its been delivered today. Hopefully I get a chance to replace it today. Had someone else change it first time (had a dash with airbags deployed and changed it whilst the dash was gutted.
    Its behind the heater controls right? any guides on accessing it or better still any easy access tricks??
  5. Re: Airbag light - suspect coding is problem
    Aug 2014
    Newport, S Wales
    So heres what ive had to do to get at the module!. Lovely jubbly. Good news its cleared two of the faults, but now have another !!!!
    Still have 00598 - Airbag ignition circuit 1 - passenger side N131
    and now have magically created 01578 which is apparently Airbag Deactivation Warning Lamp; Passenger Side (K145) Is this saying my passenger
    Any ideas?
    Attachment 25563Attachment 25564Attachment 25565
  1. Replies: 3
    Last Post: 29-02-2012, 10:41 PM
  2. Question Suspect Clutch Problem
    By fedex1 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-05-2011, 07:30 PM
  3. Another airbag light problem
    By Chriseybaby in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-04-2010, 10:55 AM
  4. Airbag Coding query
    By chris_clemo in forum VCDS - Help Requests
    Last Post: 01-02-2009, 10:05 PM
  5. Suspect sensor problem
    By W.Murphy in forum 80 - 90
    Last Post: 22-07-2008, 04:00 PM
