Thread: 2.0 TDI BLB not going well at low rmp
Results 11 to 20 of 22
  1. Re: 2.0 TDI BLB not going well at low rmp
    #11
    Aug 2014
    essex
    I fixed mine yesterday.
    Click this link below as this was my problem;
    no oil getting to tappets - help
  2. Re: 2.0 TDI BLB not going well at low rmp
    #12
    Aug 2014
    Podgorica
    I control my tappets and they are ok.. ;(
  3. Re: 2.0 TDI BLB not going well at low rmp
    #13
    Aug 2014
    essex
    Have you had your timing set up on vcds. A few degrees out can cause alot of problems as ive recently found out with my bora tdi
  4. Re: 2.0 TDI BLB not going well at low rmp
    #14
    Aug 2014
    Podgorica
    You mean the timing crankshaft? i chek this and it's ok...
  5. Re: 2.0 TDI BLB not going well at low rmp
    #15
    Aug 2014
    essex
    I mean the torsion value. It can only be measured with vcds. If its slightly out it can cause problems
  6. Re: 2.0 TDI BLB not going well at low rmp
    #16
    Aug 2014
    Podgorica
    the torsion value is -0.5kw
  7. Re: 2.0 TDI BLB not going well at low rmp
    #17
    Aug 2014
    essex
    Its not the kw block. I believe its the block beside it. 4th block along that just measures degrees
  8. Re: 2.0 TDI BLB not going well at low rmp
    #18
    Aug 2014
    Podgorica
  9. Re: 2.0 TDI BLB not going well at low rmp
    #19
    Aug 2014
    essex
    Oh that has kw as well. Ive seen them without the kw. That is within spec. Its eliminated that at the least.
    Just for reference my bora had a tuning chip fitted and i recently removed it and it feels like its got no low down power now. Maybe thats just how standard tdi pds feel?
  10. Re: 2.0 TDI BLB not going well at low rmp
    #20
    Aug 2014
    essex
    Also if youve had turbo off has the vnt arm been set at the correct length? It can be too long so the vanes are not working at low rpm
  1. 2.0 tdi BLB engine
    By anilkumar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-09-2010, 04:02 PM
  2. 2.0 tdi [blb]throttle adaptation
    By dabsline in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-08-2010, 10:52 AM
  3. Please Help 05 A4 2.0 TDI (BLB engine)
    By r0nn13 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-02-2010, 08:43 AM
  4. 2.0 tdi [blb]
    Last Post: 17-12-2009, 12:11 PM
  5. Please Help Passat TDI PD130 kangarooing at low revs low load
    By phil2401 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-09-2009, 06:14 PM
