Thread: Loud rattle with engine running in neutral, dmf on its way out?
  1. Loud rattle with engine running in neutral, dmf on its way out?
    Mar 2011
    peterborough
    I have a 09 highline estate with the 140 CR tdi engine on 108k. I don't drive the car very often as the wife ferries the kids around in it. Anyway got in today and there is a noticeable rattle coming from the engine/gearbox with the engine running and in neutral.
    Am I right in thinking this is likely to be the dmf or the release bearing? If so Either way I take it will be best to renew clutch/dmf & release bearing at the same time, due to the miles done and cost of gearbox removal labour etc?
    Any idea what kind of costs I'm looking at fitted?
    Thx in advance
  2. Re: Loud rattle with engine running in neutral, dmf on its way out?
    46 Post(s)
    When you press the clutch in does the noise stop?
  3. Re: Loud rattle with engine running in neutral, dmf on its way out?
    Mar 2011
    peterborough
    Sorry yes meant to put that, with the clutch depressed it stops.
  4. Re: Loud rattle with engine running in neutral, dmf on its way out?
    46 Post(s)
    Clutch and DMF, you can keep driving it till it judders, it just won't be nice to drive.
  5. Re: Loud rattle with engine running in neutral, dmf on its way out?
    Mar 2011
    peterborough
    Many thanks for the Info much appreciated
    When u say judders, do u mean as you get to the biting point?
    Also do u know roughly what kind of money to get it changed at a garage? I've done gearbox off on older vw 5 speeds but not sure I'd be able to do a 6 speed with a couple of jacks:-/
  6. Re: Loud rattle with engine running in neutral, dmf on its way out?
    Norfolk
    Quote Originally Posted by ThEgOg View Post
    It isn't a hard job with a couple of jacks. Parts are expensive so garage can charge £650 - 1000. Depend where you live etc.
  7. Re: Loud rattle with engine running in neutral, dmf on its way out?
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    And get everything done while you are there, silly to have to pull it all apart again in a few thousand to change the friction plate or release bearing.
  1. Loud crack, now rattle over uneven ground
    By chips in forum Alhambra
    Last Post: 23-06-2013, 01:39 PM
  2. Question loud rattle on shutdown DMF failure symptom?
    By rs250gpracer in forum Golf MK4 - 1999 - 2004
    Last Post: 03-05-2010, 04:26 PM
  3. ATD engine DMF?
    By batteryman in forum Golf MK4 - 1999 - 2004
    Last Post: 06-08-2009, 09:30 AM
  4. Please Help Engine cutting off on idle neutral gear
    By mujahid84 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-08-2009, 10:00 PM
  5. Please Help 16V KR Engine engine is loud at 3-4K RPM
    By cnjihia in forum Golf MK2 - 1984 - 1992
    Last Post: 28-11-2008, 12:23 PM
