Thread: 2003 VW Passat GLS Sedan - Passenger Side Floorboard Wet - Warning Messages
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: 2003 VW Passat GLS Sedan - Passenger Side Floorboard Wet - Warning Messages
    Aug 2014
    Waterloo, New York, United States
    Quote Originally Posted by Doctle Odd View Post
    I removed the cabin filter assembly, and did find that the foam filter seal? that is in there was wet on the one side (and squished on the one side). I cleaned and let dry and it straighted out enough to re-use. Also the rubber seal
    was broken. I ended up sealing all with rtv silicone gasket maker, and put all back together. Hopefully that fixes the problem. Ill let you know next the I go through the car wash. Thanks for your help!
  2. Re: 2003 VW Passat GLS Sedan - Passenger Side Floorboard Wet - Warning Messages
    Sep 2013
    preston
    I have just done ths on mine, i was getting intermoittent esp light and glow plug light and then going off on its own and it all seemed to be related to raining etc outside.
    I removed the carpet and found it a bit damp around the control module on the floor, I removed the scuttle panel and poured about a litre of water down the scuttle panel and it poured staright out of the drain and no water come into the car.
    I then removed the cabin filter surround with the three nuts and found the seal in a poor condition and all split and the inner sponge part was a little wet.I used silicone sealant to replace this rubber seal and put it all back together, I think it started with the area around the cabin filter surround containing alot of debris and this allowed the water to sit there and enter the car, I then dried the floor area around the control unit and sprayed the wiring and control unit with wd40 to disperse any remaining water.
    Will keep updated next time we get a good downpour and go out for a drive!!
  3. Re: 2003 VW Passat GLS Sedan - Passenger Side Floorboard Wet - Warning Messages
    Oct 2005
    For peace of mind, you might want to put a few sachets of silica gel (or other desiccant) in the CCM enclosure.
  1. Leaky passenger floorboard 93 passat
    By DBodner in forum Early Passat Forum - Pre 97
    Last Post: 09-08-2010, 10:50 AM
  2. Please Help Wet Carpet on Passenger Side
    By Tyroaudi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-04-2010, 10:03 AM
  3. Wet right-hand side passenger floor
    By neatneat1 in forum Bora - 1998 - 2005
    Last Post: 21-01-2010, 02:11 PM
  4. vw passat 1.8t 201 wet footwell passengers side
    By passahat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-09-2009, 11:55 AM
  5. 2003 GLS Turbo Hatchback
    By vkohoutjr in forum Beetle 2000-
    Last Post: 16-02-2008, 09:58 PM
