Thread: Where is the Coolant temperature sensor?
  1. Where is the Coolant temperature sensor?
    Feb 2010
    uk
    Car is 2008 Audi A3 1.9TDie
    I hv had warm start issues sometimes lazy, but today just wouldn't start.
    I have found what I think is the G83 'grey' 2 pin sensor- just by dipstick behind radiator car started straight away- no sure if this is a coincidence as car had cooled down.
    I just cant find the other G63 'green' 4 pin sensor.
    Any ideas please, pics would be appreciate
    thanks in advance
    Audi A4 2002 1.8T Quattro Avant
    No modifications
  2. Re: Where is the Coolant temperature sensor?
    Feb 2010
    uk
    Answering my question in case it helps someone else
    There are 2 grey 2-pin sensors on this engine
    1 on radiator outlet and 1 rear of engine, accessed just under air hose
    No modifications
  3. Re: Where is the Coolant temperature sensor?
    Jan 2011
    East Kent
    Just to be sure, are you aware of this common issue being caused by the starter motor?
    Thread: Audi a3 tdi
    Disconnecting the coolant temperature sensor just forces the ecu into thinking that the engine is cold, thereby it injects fuel when the engine is actually warm (which it normally would not do) and this alleviates a weak starter motor.
    Previous: 2005 A3 1.9tdi SE
    2009 Audi A3 2.0tdi 138bhp SE
  4. Re: Where is the Coolant temperature sensor?
    Feb 2010
    uk
    Quote Originally Posted by alankru View Post
    Thread: Audi a3 tdi
    Thanks for this:
    I went for the CTS as
    1 The starter was turning but engine not starting- I assumed it was CTS type issue as it was on warm start and wondered if engine was flooded?
    2 I had CTS and camshaft pos sensor codes on VCDS- I only managed to replace radiator sensor with a used genuine CTS and it seems to have helped. However Im waiting for th new sensor arrive from Poland.
    I will read the other thread and feedback
    No modifications
  1. Temperature coolant sensor?
    By garyizme in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-12-2012, 12:19 AM
  2. VW LT coolant temperature sensor
    By ProK in forum The Commercial Range
    Last Post: 25-03-2011, 04:13 AM
  3. Coolant temperature sensor
    By timsmith in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-10-2010, 08:29 PM
  4. Question Coolant temperature sensor
    By animal in forum Polo - Derby - Lupo - Fox
    Last Post: 02-01-2009, 11:18 PM
  5. Coolant Temperature Sensor
    By shahabudeen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-07-2007, 09:25 AM
