Thread: glow plug light flashing
Results 1 to 10 of 14
  1. glow plug light flashing
    Sep 2007
    i have an alhambra 1.9 tdi and the glow plug light works correctly on start up , after about 30 seconds it comes on and flashes all the time, anyone have any ideas?
    mike
  2. Re: glow plug light flashing
    1837 Post(s)
    Get a fault code read done, it’s probably a faulty brake light switch or coolant temperature sender.
  3. Re: glow plug light flashing
    May 2007
    Liverpool
    Also check that all the brake lights are working. This can make the glow plug light flash.
    1998 Audi A4 2.8 V6 quattro
  4. Re: glow plug light flashing
    May 2007
    Hi had this the other week - of course just the evening before we were away for a week so I dropped it into my local garage for a diagnostic. As above it was the brake light switch - about £10-£15)
    Hope this is of help
    Robin
  5. Re: glow plug light flashing
    Dec 2008
    Quote Originally Posted by Robin Vitiello View Post
    Robin
    how do you remove the brake light switch
  6. Re: glow plug light flashing
    if you look upwards from the brake pedal under the dash there will be one or two swithes there twist the switch ant i clockwise lower it down then remove the connector , fitting is the reverse of removal . make sure it is the right switch if there are two
  7. Re: glow plug light flashing
    1837 Post(s)
    The problem is not removing the switch, it is fitting the new one without damaging it, they are a simply useless design and that is after at least five revisions in the last few years.
  8. Re: glow plug light flashing
    you are a million gig hard drive crasher the forum would collapse if you did'nt
    sign in . you certainly know these cars inside out ...you the man ....
  9. Re: glow plug light flashing
    1837 Post(s)
  10. Re: glow plug light flashing
    Apr 2007
    Same problem with my Golf TDI 115.
    Mine was two brake light bulbs only - no switch, just the bulbs.
    Common fault, changed both brake light bulbs and Bobs your uncle..... cost £1.25 in toto...
  1. Flashing Glow Plug Light??
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-11-2009, 09:49 PM
  2. A4 TDi - glow plug light flashing, will not rev up past idle speed
    By tom fenton in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2009, 07:49 PM
  3. Glow plug warning light flashing.
    By Nebooaw in forum Passat - Archive Topics
    Last Post: 06-07-2007, 07:37 PM
  4. Glow Plug Warning Light Flashing
    By grange in forum Audi A4 - Archive Topics
    Last Post: 05-07-2007, 01:04 PM
  5. Glow Plug Warning Lamp Flashing
    By apache24uk in forum Polo - Derby - Lupo - Fox
    Last Post: 10-04-2007, 09:20 PM
