Thread: Graphics card upgrade?
Results 1 to 10 of 13
  1. Graphics card upgrade?
    Apr 2013
    Glasgow
    I have a Radeon HD7770 which seems to perform quite well for my everyday tasks and tad of gaming, but tends to slow down when editing video from my Hd 1080 camera. Not initially but only after a few edits, probably because too much in memory. I can add RAM if you think that's an issue.
    So I am in the market for a new graphics card, I am looking for thoughts, advice and comments, before and helping me make a choice.
    Budget is about £150, I am looking at a R9270x which can be had for £159 however a friend stated that the Nvidia range is superior, any comments?
  2. Re: Graphics card upgrade?
    Oct 2005
    What CPU do you have?
    How much RAM do you have?
    What editing suite are you using?
  3. Re: Graphics card upgrade?
    Apr 2013
    Glasgow
    16GB 1600 RAM - motherboard allows 32,
    CPU is a Intel Core i3 3220 3.30GHz,
    Video edit is - MAGIX Movie Edit Pro 2014.
  4. Re: Graphics card upgrade?
    Oct 2005
    I last upgraded in Feb '13 so I'm not quite as sharp as I used to be, but that i3 is more than likely the bottleneck.
    What mobo do you have?
  5. Graphics card upgrade?
    Apr 2013
    Glasgow
    Gigabyte GA-Z77-DS3H Socket 1155
    I did think the i3 could be an issue but as upgraded from a core two duo P4 was the best I could afford at the time Oct last year, if I go i5 that is £100 plus then graphics card will have to stay the same for now.
  6. Re: Graphics card upgrade?
    Oct 2005
    MAXIS recommend at least a quad core CPU for HD/4K video editing and your i3 is 'just' a dual core.
    You can see the supported list of CPUs over on Gigabyte's site but if it were me I'd be looking to upgrade the CPU.
    An i7 3770 is slightly out of your reach on the budget you've quoted but you might be lucky and find a decent used one.
    Failing that an i5 3570 should do.
    There are various flavours of the above CPUs too, T, S, K etc - make sure you have a proper read on the qualities of each before you do anything and if you are a member of any nerdy forums - always take their advice over mine
  7. Re: Graphics card upgrade?
    Apr 2013
    Glasgow
    Just goes to show you should read the specs on the side of the box, looks like processor upgrade needed, thanks for your input.
  8. Re: Graphics card upgrade?
    Oct 2005
    Good luck
  9. Re: Graphics card upgrade?
    Sep 2009
    London/Bucks England
    I wouldnt worry about the graphics hard an HD7770 is pretty decent. I am still running an HD6870 and it does most things, including BF4 fine. Your bottleneck will be RAM & CPU, encoding/editing doesnt require any 3D graphics processing it's all raw CPU power for rendering.
    If your hard drive is slow I would say just tack on some more RAM. I have an I7 3770 paid for by work. It's marginally better for encoding than my AMD, but my AMD is a 6 core but multithread is much better on my AMD by a long shot and thats slower on raw clock speed.
    You should get a pretty decent encoding rate with an i5, but I cant help but think you would get more bang for your buck with and AMD rig. But if you can get an i5 then go for it. How much ram are you sitting on at the moment?
    151 PS @ 3800 rpm 1.6 8V MPi - 31.5mpg urban <-- Happy days
    123k On the clock and counting. (25k on the block)
    I need all your V-Powers.
  10. Re: Graphics card upgrade?
    Sep 2011
    Lurking over a keyboard ...
    My opinion is for budget set by Tabletski I'd go for a i5 3570K and overclock it for extra bang for buck!
    There have been times where AMD have been my choice for a rig but for a long time Intel have the crown.
    You can see an i5 3750K vs FX 8350 here (couldn't find a FX 9xxx review) Link:- AMD FX-8350 Image Editing and Video Encoding Performance | bit-tech.net
  1. Graphics card problem?
    By scotty33 in forum Home Tech Shed
    Last Post: 12-11-2013, 09:59 PM
  2. Audi A6 MMI Graphics
    By JannerAudi in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-11-2013, 10:55 PM
  3. Question TDI no oil pressure warning light with 'graphics dash'
    By oldsod in forum Golf MK5 - 2004 - 2009
    Last Post: 21-08-2011, 09:49 AM
  4. Please Help Door Graphics
    By flyingbanana in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 15-02-2011, 08:59 PM
  5. Upgrade to lossless.... upgrade your life
    By Jop in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-04-2009, 09:57 AM
