Thread: Canbus gateway
  1. Canbus gateway
    Apr 2009
    scotland
    Hi there would this canbus gateway cure the flat battery issue on a 2005 Golf plus , part number 1K0907530K.. i am fitting a rcd 310 from a 2011 vw polo ..
    i will recode the gateway just wondering if this letter of gateway would be ok .
  2. Re: Canbus gateway
    46 Post(s)
    Yup going by other threads you need to upgrade it if you're fitting a newer headunit from newer models.
    Maybe do a search on the forum just to see.
  3. Re: Canbus gateway
    Apr 2009
    scotland
    The new canbus would be a (K) should the K be ok its from a 2007 Golf
  4. Re: Canbus gateway
    Jan 2012
    Coding Something
    Always find the very latest gateway version, if its cost effective of course.
  5. Re: Canbus gateway
    Apr 2009
    scotland
    So would you think the K version would work and also how will i know if its worked for this headunit ..once coded ..
  6. Re: Canbus gateway
    Apr 2009
    scotland
    Hi there would the K version work and cure the battery drain and also how do you know if its worked once coded ,
  1. Canbus gateway
    By PHASTAZPHUK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-11-2013, 10:38 AM
  2. Replacement CANBUS gateway needs coding - Manchester
    By squowse in forum VCDS - Help Requests
    Last Post: 20-08-2012, 12:49 PM
  3. VAGCOM Canbus Gateway upgrade - Gloucestershire Area
    By IndigoBlue in forum VCDS - Help Requests
    Last Post: 24-04-2011, 11:07 AM
  4. GATEWAY...step by step guide on how to re-code the gateway
    By maddogphysics in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-06-2010, 01:15 PM
  5. CanBus?
    By b0redom in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-11-2007, 07:13 PM
