Thread: Parking Aid Issue with A8 3.0 TDI
  1. Parking Aid Issue with A8 3.0 TDI
    Mar 2009
    Cheshire
    My 2005 A8 3.0TDI has an intermittent issue with the parking sensors
    The issue is with the front sensors. Sometimes the front sensor tone gives a permanent tone (as if you are at the limit i.e too close) even when there is nothing in front of the car which would set the sensors off. While the front tone is sounding if you then reverse the rear tone and the front tone beep together like to what I can only describe how a child would make a police siren noise i.e der-der, der-der. I have a basic vag com scanner and it shows no fault codes for the parking sensors.
    As anyone got any suggestions as to what this could be?
  2. Re: Parking Aid Issue with A8 3.0 TDI
    Nov 2009
    46 Post(s)
    Try and get it scanned with the full VCDS version. Could be anything down to a failing control module, sensors, sensor wiring but a scan with a compatible tool is needed
  3. Re: Parking Aid Issue with A8 3.0 TDI
    Jan 2010
    Northants
    Check there isn't any flaking paint around the front sensor, I think it can cause false signals!
  4. Re: Parking Aid Issue with A8 3.0 TDI
    Mar 2009
    Cheshire
    I am still getting intermittent problems with the front parking sensors. I now have VCDS so have run a check of which the results are pasted in below.
    Oddly it gives no fault codes against Parking Assist. The sensors are clean and have no flaking paint etc. Any advice on this would be appreciated.
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    Saturday,25,October,2014,12:54:56:65217
    Chassis Type: 4E (4E0)
    Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 18 19 1E 25 34 36 37 38
    42 46 47 4F 52 53 55 56 57 61 62 69 72 76 77
    VIN: WAUZZZ4E75N001760 Mileage: 129970km/80759miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: Not registered 0011
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    1E-Media Player 2 -- Status: Cannot be reached 1100
    34-Level Control -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    38-Roof Electronics -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    57-TV Tuner -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: Cannot be reached 1100
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4E0 910 401 H HW: 4E0 907 401 B
    Component: 3.0L V6TDI G000AG 0030
    Revision: --H01--- Serial number: AUX3Z0D4142563
    Coding: 0011773
    Shop #: WSC 02313 785 00200
    VCID: 2045F8C0F33D221EB43-8075
    No fault code found.
    Readiness: 0 0 1 1 1
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4E0 910 156 F HW: 09L 927 156
    Component: AG6 09L 3.0lTDI RdW 0060
    Revision: 00000001 Serial number: 0026707
    Coding: 0000001
    VCID: 254BE9D4EC1FC736C75-8070
    Address 03: ABS Brakes Labels: 4E0-910-517.lbl
    Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
    Component: ESP 5.7 allrad H44 0510
    Coding: 0008357
    Shop #: WSC 02313 000 00000
    VCID: 2241F2C8FD31300EA27-8077
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - - - Intermittent
    Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
    Part No SW: 4E0 910 131 HW: 4E0 907 181 A
    Component: FBS AUDID3 H12 0200
    Revision: 02005112 Serial number: AUX3Z0D4142563
    Coding: 0265216
    Shop #: WSC 00847 210 80521
    VCID: D8B510206BED2ADE0C3-808D
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: ELV XXXX
    Address 06: Seat Mem. Pass Labels: None
    Part No SW: 4E0 910 760 C HW: 4E0 959 760
    Component: Sitzmemory BFS H08 0060
    Revision: 00000000 Serial number: 5DS 008 795-03
    Coding: 3670112
    Shop #: WSC 00000 785 00200
    VCID: 234FF7CCE22B3906A91-8076
    Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
    Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 300FI047536345
    Coding: 0000002
    Shop #: WSC 00752 210 91076
    VCID: 3A712AA875A158CE9A7-806F
    Subsystem 1 - Part No: 4E0 910 609 A
    Component: Bedienteil MMI H42 0020
    Subsystem 2 - Serial number: 322EU047506969
    Subsystem 3 - Serial number: 7424.05.040000000000010063ÿ
    Subsystem 4 - Serial number: 010063ÿ
    Address 08: Auto HVAC Labels: None
    Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
    Component: KLIMAAUTOMAT 016 0300
    Revision: 00000025 Serial number: 00000000045434
    Coding: 1067009
    Shop #: WSC 02311 785 00200
    VCID: 1B3FCF2CDA5B01C6611-804E
    Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
    Part No SW: 4E0 910 279 J HW: 4E0 907 279 J
    Component: ILM Fahrer H12 0190
    Coding: 0120001
    VCID: 2F670BFCBEE38D663D9-807A
    Subsystem 1 - Part No: 4E2 910 113 B
    Component: Wischer WWS D3 H50 0420
    Coding: 00000034
    Shop #: WSC 02313
    Address 0E: Media Player 1 (R199) Labels: 4E0-035-785.lbl
    Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
    Component: SG ext.Player H20 0850
    Revision: 00000000
    Coding: 010000
    Shop #: WSC 00000 000 00000
    VCID: 2B5F1FEC4AFBF146111-807E
    Address 15: Airbags Labels: 4E0-910-655-84.lbl
    Part No SW: 4E0 910 655 HW: 4E0 959 655 G
    Component: Airbag 8.4E+ H10 0940
    Coding: 0431707
    VCID: E3CF37CC22ABF906691-80B6
    Address 16: Steering wheel Labels: 4E0-910-549.lbl
    Part No SW: 4E0 910 549 HW: 4E0 953 549
    Component: Lenksäulenmodul H13 0040
    Coding: 0112141
    VCID: E5CB29D42C9F8736875-80B0
    Component: Lenkradmodul H04 0080
    Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
    Part No SW: 4E0 910 950 F HW: 4E0 920 950 F
    Component: KOMBIINSTR. VDO H47 0200
    Revision: D02 Serial number: AUDID3D5000166
    Coding: 0000428
    VCID: 2757E3DC9613D526F59-8072
    Address 18: Aux. Heat Labels: None
    Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
    Component: Heizgeraet H07 0100
    Revision: 0000000B Serial number: 00000009006406
    Coding: 0000001
    VCID: 1A31CA28D56178CE7A7-804F
    Address 19: CAN Gateway Labels: 4E0-910-468.lbl
    Part No SW: 4E0 910 468 HW: 4E0 907 468 A
    Component: Gateway H07 0070
    Revision: 07 Serial number: 16003044270C46
    Coding: FDFE7BDE2B3504
    Shop #: WSC 01130 210 66681
    3 Faults Found:
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 106
    Mileage: 129977 km
    Time Indication: 0
    Date: 2014.10.25
    Time: 12:47:52
    02077 - Media Player Position 2 (R119)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 106
    Mileage: 129977 km
    Time Indication: 0
    Date: 2014.10.25
    Time: 12:48:47
    01303 - Telephone Transceiver (R36)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 106
    Mileage: 129977 km
    Time Indication: 0
    Date: 2014.10.25
    Time: 12:48:47
    Address 1E: Media Player 2
    Cannot be reached
    Address 25: Immobilizer Labels: 4E0-910-131.lbl
    Coding: 0265216
    Component: ELV XXXX
    XXXXXXXXXXX ELV XXXX
    Address 34: Level Control Labels: 4E0-910-553.lbl
    Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
    Component: LUFTFDR.-CDC H06 4480
    Coding: 0015520
    VCID: 2855E0E09B0DDA5EFC3-807D
    3 Faults Found:
    01598 - Drive Battery Voltage
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 4
    Fault Frequency: 4
    Reset counter: 122
    Mileage: 129716 km
    Time Indication: 0
    Date: 2004.03.25
    Time: 00:47:54
    00776 - Level Control System Sensor; Left Front (G78)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 3
    Fault Frequency: 255
    Reset counter: 255
    Mileage: 129716 km
    Time Indication: 0
    Date: 2004.03.25
    Time: 00:00:17
    01769 - Sensor for Vehicle Leveling; Front Right (G289)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 168
    Mileage: 129716 km
    Time Indication: 0
    Date: 2004.03.25
    Time: 00:00:18
    Address 36: Seat Mem. Drvr Labels: None
    Component: Sitzmemory FS H08 0060
    Coding: 3670114
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
    Component: MNS ECE H43 1060
    Revision: 00000000 Serial number: 353FL047523164
    VCID: 3B7F2FAC7A9B61C6811-806E
    Address 38: Roof Electronics Labels: 4E0-910-135.lbl
    Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
    Component: Dachknoten D3 H01 0090
    Serial number: 00000411700003
    Coding: 0035968
    VCID: 1D3BC134C44F0FF69F5-8048
    Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
    Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
    Component: Türsteuer.FS BRMH01 0060
    Coding: 0026926
    Address 46: Central Conv. Labels: 4E0-910-289.lbl
    Part No SW: 4E0 910 289 A HW: 4E0 907 289
    Component: Komfortgeraet H04 0040
    Revision: 00400004 Serial number: W040406070305
    Coding: 0004345
    Subsystem 1 - Part No: 4E0 910 853
    Component: Heckdeckel H06 0050
    Subsystem 2 - Part No: 4E0 907 719
    Component: Neigungssensor H03 0020
    Address 47: Sound System Labels: 4E0-910-223.lbl
    Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
    Component: DSP-Amp.-High H13 0460
    Revision: PROD_01 Serial number: 00000000003585
    Coding: 0000013
    VCID: 2A511AE88501E84EEA7-807F
    Address 4F: Centr. Electr. II Labels: None
    Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
    Component: ILM Beifahrer H09 0040
    Revision: Serial number: 00000000041830
    Coding: 0010101
    VCID: 1E39C638C94914EE86F-804B
    Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
    Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
    Component: Türsteuer.BF BRMH01 0060
    Coding: 0026926
    1 Fault Found:
    02115 - Locking Unit for Central Locking
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 106
    Mileage: 129968 km
    Time Indication: 0
    Date: 2014.10.25
    Time: 12:50:28
    Address 53: Parking Brake Labels: 4E0-910-801.clb
    Part No SW: 4E0 910 801 A HW: 4E0 907 801
    Component: EPB AV1C1010 H01 1010
    Revision: AV1C1010
    Coding: 0000221
    Shop #: WSC 06529 000 1048576
    1 Fault Found:
    02596 - Rear Brake Pads Worn
    Freeze Frame:
    Fault Status: 01111000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 57
    Time Indication: 0
    Date: 2064.00.00
    Time: 00:00:00
    Freeze Frame:
    Voltage: 9.11 V
    Count: 61
    Address 55: Xenon Range Labels: 4E0-910-357.lbl
    Part No SW: 4E0 910 357 HW: 4E0 907 357
    Component: Pre-AFS H01 0040
    Coding: 0000001
    VCID: E2C132C83DB1F00E627-80B7
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4E0 035 541 B
    Component: TUNER EU/US/RDW H41 0630
    Revision: 00000000 Serial number: 304FR047595174
    Coding: 0000001
    VCID: 31630D84A8D79B962BD-8064
    Address 57: TV Tuner
    Cannot be reached
    Address 61: Battery Regul. Labels: 4E0-910-181.lbl
    Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
    Component: J0644 BEM H11 0510
    Revision: 00000000 Serial number: 00000000001169
    Shop #: WSC 00847 210 08795
    Subsystem 1 - Part No: 4E0 915 105 AV
    Component: von VA0 1405270037
    Coding: 344530393135313035415656413031343035323730303337
    Shop #: WSC 12345 128 00289
    Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
    Component: Türsteuer.HL BRM002 0060
    Coding: 0026926
    Address 69: Trailer (J345) Labels: 4E0-907-383.clb
    Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
    Component: Anhaenger H09 0100
    Revision: 2A001001 Serial number: 00000194546958
    Coding: 0100000000000000
    VCID: 31630D8468D79B962BD-8064
    Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
    Component: Türsteuer.HR BRM002 0060
    Coding: 0026926
    Address 76: Park Assist Labels: 4E0-910-283.lbl
    Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
    Component: Parkhilfe 8-Kan H12 0020
    Revision: --.--.-- Serial number: 08730413301384
    Coding: 0011008
    VCID: 2143FDC4F8372B16BBD-8074
    Address 77: Telephone
    Cannot be reached
  5. Re: Parking Aid Issue with A8 3.0 TDI
    Sep 2011
    Lurking over a keyboard ...
    Perhaps do measuring blocks in module 76, Link:- http://www.audi-portal.com/en/diagno...u_11893.html#1
    You may find that one or more sensor is occasionally misreading distance
  6. Re: Parking Aid Issue with A8 3.0 TDI
    Mar 2009
    Cheshire
    After performing a measuring blocks test. It seems that the front centre right sensor is measuring a shorter distance than the centre left sensor. However this is intermittant. Sometimes it measures ok. Other times not.
    If I wanted to gain access to the sensor can this be done by removing the radiator grill alone? Or does the whole front bumper cover need to be removed?
  1. Visual parking aid?
    By thechrism in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-03-2014, 08:43 AM
  2. Retrofit, parking aid plus.
    By sacha35 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-12-2012, 05:53 PM
  3. Parking aid upgrade
    By A82004 in forum A8 - S8 - V8
    Last Post: 17-07-2012, 10:36 PM
  4. Parking Aid not working?
    By The-Stig in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-01-2010, 01:19 AM
  5. Audi Parking Aid
    By Robertarwel in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-04-2008, 06:55 PM
