Thread: Cannot open passenger door from inside or outside.
  1. Cannot open passenger door from inside or outside.
    Scotland
    As per the title I cannot get the passenger door open on the car. When opening the doors from the fob or the internal switch I hear the normal click from the passenger door followed by two quieter clicks.
    I would assuming the locking mechanism is knackered but it's going to be hard to replace it if I can't open the door at all!
    Anyone have any tips that might help get the door open?
    My rides: 2015 Passat Estate SE Business 150PS and a 2011 Fabia vRS.
  2. Re: Cannot open passenger door from inside or outside.
    Aug 2008
    East Anglia, UK
    Quote Originally Posted by CMcK View Post
    I've only just had this happen on my dads 08 GT golf, I followed this guide here
    http://www.vwgolf.net.au/showthread....ked-stuck-FIX!
    I found it was the main plug, but checked everything. Although he's not sure if its failed once (finger trouble).
    Kev.
    '08 GOLF GT TDI 140
  3. Re: Cannot open passenger door from inside or outside.
    Scotland
    I eventually got the door fixed thanks to Hepburn Motors in Crook of Devon. He was able to get the door card off from the inside without damaging it and release the door from there.
    I replaced the lock mechanism with a third party part which lasted all of a few weeks. It would almost unlock the door so you had to give the door a thump near the handle to complete the unlocking process. A replacement part developed the same problem. I've since fitted a genuine VW mechanism.
  1. passenger door wont open from inside or outside and driver window not working
    By nickeym1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2014, 11:49 AM
  2. Please Help Passenger rear door wont open from inside?
    By BigPhysco in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-05-2013, 09:17 PM
  3. Passenger door difficult to open from inside
    By noonoo63 in forum Golf MK6 - 2009 - 2013
    Last Post: 20-01-2013, 05:57 PM
  4. Passenger door will not open from inside or outside
    By Cronus in forum Early Passat Forum - Pre 97
    Last Post: 07-10-2008, 11:00 AM
  5. Front Passenger Door will not open using inside handle
    By silentbazz in forum Golf MK4 - 1999 - 2004
    Last Post: 23-04-2008, 01:38 PM
