Thread: 56 Beetle headlight problems
  1. 56 Beetle headlight problems
    Jun 2012
    United Kingdom
    Hi guys, the other half has a 56 plate beetle which has recently starting giving us some headlight problems.
    The O/S low beam bulb went out a month or so ago and we replaced the bulb. The same bulb went out again yesterday, (when I looked over it I couldn't see any signs of damage, the filament still looked solid etc but I haven't confirmed this). We replaced it today and tested it working, the bulb then went out again this evening.
    The fuses look fine and are 15 amp (I assume these are the standard ones)
    Any thoughts or suggestions as to what I can try next?
  2. Re: 56 Beetle headlight problems
    May 2007
    17 Post(s)
    Is the headlamp locked in correctly? When it isn't working, try and push the headlamp in and see if the lamp lights. Sometimes if the lamp isn't fully in, the connector on the lamp doesn't mate up with the one on the body.
    Jim.
  3. Re: 56 Beetle headlight problems
    Jun 2012
    United Kingdom
    Hi Flash2,
    Everything seemed to be located ok, all other lights work in the unit. I'll check it all over this evening with a multi-meter, thanks.
  4. Re: 56 Beetle headlight problems
    Jun 2012
    United Kingdom
    Quote Originally Posted by Flash2 View Post
    Jim.
    It's always the simple things! Tested all the bulbs, wiring etc no obvious faults. Knocked the unit by mistake and it worked! Have reseated it and seems to be alright
  5. Re: 56 Beetle headlight problems
    May 2007
    17 Post(s)
    If I got a pound every time I've seen that, I'd be two pounds better off
    Glad you got it sorted.
    Jim.
  1. beetle 1.6SR 2001 - block 032 problems
    By TapMyHed in forum Beetle 2000-
    Last Post: 03-11-2010, 01:12 PM
  2. Beetle idle problems
    By waynetdi130 in forum Beetle 2000-
    Last Post: 11-04-2010, 04:07 PM
  3. 1999 New Beetle Manual Transmission Problems
    By sorin1307 in forum Beetle 2000-
    Last Post: 12-11-2009, 09:08 PM
  4. Help, my new beetle is causing me problems!
    By lauren2405 in forum Beetle 2000-
    Last Post: 31-10-2009, 07:00 PM
  5. 2000 beetle alarm problems
    By turbobugger in forum Beetle 2000-
    Last Post: 21-03-2008, 04:05 AM
