Thread: Permanent live from battery to rear
  1. Permanent live from battery to rear
    Apr 2014
    Hockley Essex
    Hi all, just wondering how to run a live from battery to rear of car for tow bar electrics as I can't seem to find a pass point on the front bulkhead of my 1999 a4 avant Quattro 2.8, silly question could I run from the permanent on the rear 12v outlet, or if I could tap in main fuse box any advice greatly appreciated thanks
  2. Re: Permanent live from battery to rear
    Mar 2009
    Manchester, England
    Hi, if you're using a bypass relay then yes you can use either one of those as long as it's a permanent live feed not just Ignition (needs to be ok for about 15a).
    Thanks.
    PF Jones Towbars | National Mobile Towbar Fitting | Audi Towbars
    We will beat any like for like price on all Witter and Westfalia Towbars 0161 872 4755
  3. Re: Permanent live from battery to rear
    Apr 2014
    Hockley Essex
    Thank you for the reply really appreciate it
  4. Re: Permanent live from battery to rear
    Apr 2014
    Hockley Essex
    Just to let you know that the live from the 12v plug in the boot was fine
  1. Question A4 B5 Avant rear washer leak - possible solution (not permanent) / further question
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-02-2013, 10:56 PM
  2. where is best place for permanent live for twin electric in 2004 audi a6 ?
    By mill9898 in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 19-07-2012, 07:34 PM
  3. Feeding live wire to battery from car
    By shakeeb786 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-06-2011, 02:35 PM
  4. XCarLink Permanent Live?
    By talllpaul in forum In Car Entertainment
    Last Post: 23-09-2010, 11:18 AM
  5. 12v Boot Socket Change to Permanent Live
    By adstalker in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-07-2010, 08:17 PM
