Thread: 2.0tdi blb missfire on light throttle around 1000-2000 rpm
  1. 2.0tdi blb missfire on light throttle around 1000-2000 rpm
    Nov 2009
    swindon uk
    So I've had this annoying what could only be described as a misfire for a while now.
    I get no DTC errors on vcds so had no basis to work from.
    So started to throw some money at it by changing the maf and map sensors.
    Made no difference. Decided to change the fuel filter even though its less than 12 months old.
    The symptom then went away.
    Drained the old fuel filter and the fuel was black.
    Am I right in thinking the tandem fuel pump at the back of the cylinder head is at fault here?
    Audi A4 saloon, 2.0L tdi s-line. Retrofitted cruise control, DIS and MFSW. VCDS user.
  2. Re: 2.0tdi blb missfire on light throttle around 1000-2000 rpm
    Pembrokeshire
    22 Post(s)
    probably, yes.
  3. Re: 2.0tdi blb missfire on light throttle around 1000-2000 rpm
    Nov 2009
    swindon uk
    All done. It's actually quite an easy job to do.
    It seems to have given the car more power too.
    And its stopped smoking.
  1. Missfire between 3000-3500 rpm.
    By Tom A. in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-03-2014, 03:24 AM
  2. A6 3.0 TDI quattro 04 juddering between 1000 and 2000 rpm
    By jameswtownsend in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-02-2013, 07:45 PM
  3. Question A4 130 TDI making sucking noise between gear change and from 1000-2000 rpm??
    By giggsy07 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-06-2011, 01:48 PM
  4. 2005 BLB Audi A4 2.0 TDI Missfire, cuting out and smoke!
    By adam6900 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-02-2011, 07:54 PM
  5. Engine Lumpy between 1000 and 2000 RPM
    By BIGMAN1976 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-04-2010, 09:56 AM
