Thread: A3 Symphony , switched output
  1. A3 Symphony , switched output
    Jan 2009
    Morning everyone ,
    Just installed a Parrot into late 2005 A3 , what I am trying to locate is a switched live output from the back of the Symphony unit to tap into for the Autoleads Sot lead and phone kit , has anyone had any success with this ?
    thanks
    Steve
  2. Re: A3 Symphony , switched output
    46 Post(s)
    You'll have to run it to the fusebox as the radios are switched on and off via the CAN connections.
  3. Re: A3 Symphony , switched output
    Jan 2009
    Hi Chris ,
    thanks for the prompt reply , that is what I have done at moment , problem I have is amped loom turns off before head unit (does not turn off till key is pulled out) and you get a "static" crack through speakers . I was hoping to find a way to get the two synced , maybe a remote output is available from unit or another power source that stops when key is removed .
    cheers
  4. Re: A3 Symphony , switched output
    Jan 2009
    Just bumping this as I am still at a loss
    thanks
  1. Replies: 4
    Last Post: 19-11-2011, 10:10 AM
  2. Question Output test
    By megger in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-07-2009, 02:33 PM
  3. power output
    By goodersthea in forum Bora - 1998 - 2005
    Last Post: 10-05-2009, 12:15 PM
  4. Question Audi A3 (2004) Symphony II to Symphony II+
    By xandertarr in forum In Car Entertainment
    Last Post: 22-10-2008, 12:49 PM
  5. Power output
    By A6TDI- quattro in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 02-12-2007, 10:23 PM
