Thread: 2.0TDI Multitronic Intermittent Starting.
  1. 2.0TDI Multitronic Intermittent Starting.
    Jun 2007
    Help please. Several times recently the engine turns over and won't start. Usually it fires on the second or third attempt. Tonight it wouldn't start and I noticed the the gear display had flashing red blocks around the symbols.
    scanned with VCDS with the following codes:
    auto trans 2 faults 005975 supply voltage P1757 open circuit intermittent and 049408 no communications with engine control module U0100 intermittent.
    ABS 01314 engine control module 004 no signal intermittent
    instruments, xenon range and immobiliser as ABS above.
    navigation 02261 data medium. 014 defective intermittent.
    central convenience 01366 opened due to crash signal.
    fault code 01314 seems a common thread but what is the source of problem?
    many thanks in advance.
    John
  2. Re: 2.0TDI Multitronic Intermittent Starting.
    May 2007
    knee deep in clunge
    14 Post(s)
    Hi replace the engine control unit voltage supply relay
    location osf E box in plenith chamber, abs and gearbox control unit losing coms with engine ecu due to voltage drop from engine ecu supply relay secondary circuit (pitted contact)
    Around £25
  3. Re: 2.0TDI Multitronic Intermittent Starting.
    Jun 2007
    That's brilliant. Thank you!!!
    i feared it was going to be another new gearbox.
    john.
  4. Re: 2.0TDI Multitronic Intermittent Starting.
    Jun 2007
    Just checked with local main dealer and they list the following relays in plenum chamber box.
    Fuel pump 395
    auto gearbox 395. ( had new one of those 6 months ago)
    secondary air pump 373
    Glow plug 457
    closed contact engine ????? 614.
    could it be the last one??
    I thought it might have been a 508 but apparently not in this car.
    Thanks again.
    John.
  1. Faulty flywheel on 2.0tdi Multitronic
    By STAGMAN in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-12-2015, 06:53 PM
  2. Hi i got a6 2.0tdi with 7 speed multitronic gearbox.
    By dands in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-12-2012, 07:53 PM
  3. New owner of A4 2.0TDI SE (140) Multitronic
    By rufus2005 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-06-2010, 01:58 PM
  4. 2.0TDi & Multitronic
    By B19RAK in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-05-2009, 07:56 PM
  5. Multitronic / 3.0TDI
    By masonj in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-03-2008, 11:32 PM
