Thread: real head scratcher
Results 1 to 10 of 13
  1. real head scratcher
    Apr 2014
    hyde
    hi all , first post so give it me straight , my 2006 1.9 tdi saloon vibrates on acceleration in higher gears round about 2000/2500 revs after a succession of garages and after spending £1400 its worse if not better , first garage , oh yea seen it lots of times change your lift pump guaranteed fixed (£340) later no difference ! next diesel specialist ,diagnosis ,new loom thats whats needed £200 ..nope ok 1 injector £370 plus fitting nope !! next garage err engine mounts knackered replace it all will be fine new engine gearbox mount rear mount stabiliser bar/mount £££££ & still vibrateing in all gears ,yet if i boot it through the gears sweet as a nut ,now im told to remove the EGR plate ? any idea gang before i top myself lol open to all suggestions except setting it on fire
  2. Re: real head scratcher
    46 Post(s)
    Have you had it scanned for faults?
    When was the fuel filer last changed?
  3. Re: real head scratcher
    Apr 2014
    hyde
    yes cheers chris its been on 2 diagnostic machines plus full service & filter changes im completely baffled im told next step is to remove the egr blanking plate ? its never ending paying out lol
  4. Re: real head scratcher
    Pembrokeshire
    22 Post(s)
    so when you say vibrates, what do you mean, a vibration through the whole car, like a misfire ??
  5. Re: real head scratcher
    Apr 2014
    hyde
    it seems to me as the engine is shakeing you can see the windscreen wipers vibrating it was only accererating up hills in 4th gear now its in all gears under any amount of engine power but after 3000 revs its smooth
  6. Re: real head scratcher
    Jul 2007
    glasgow
    35 Post(s)
    Is it the clutch or pressure plate??
    so you reckon the higher the engine is revving the better ? That rules the turbo out to me...
  7. Re: real head scratcher
    Oct 2010
    walsall
    This sounds like the dual mass flywheel, when they go they cause vibration through all the gears.
  8. Re: real head scratcher
    Apr 2014
    hyde
    very interesting sar02 i will look into that thanks i noticed today it was bad in all gears but on freewheeling i revved it like mad & the engine was smooth ,put it into gear and same old story ..the plot thickens lol
  9. Re: real head scratcher
    Jul 2007
    glasgow
    35 Post(s)
    Yep, put in gear & vibrates.
    Clutch or pressure plate
  10. Re: real head scratcher
    Apr 2014
    hyde
    many thanks for all advice gents i have a better idea where to look now cheers ,
  1. My first real R8 drive
    By r8rob in forum R8
    Last Post: 03-07-2014, 07:09 PM
  2. Real Tricky One This
    By Doddy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-10-2011, 12:01 PM
  3. Real BMP output...
    By randall977 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-02-2010, 11:32 PM
  4. Real Spec
    By Mike'A in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-01-2010, 12:29 AM
  5. Audi S5. The Real Thing
    By decksurgeon in forum Chat - Completely Off Topic
    Last Post: 01-03-2007, 01:56 AM
