Thread: VW Polo ABS Light not again!
  1. VW Polo ABS Light not again!
    Jul 2006
    The ABS & brake warning lights on my car have been going on and off intermittently. I had a diagnostic test months ago and it looked like the rear left ABS sensor. This was replaced yesterday (albeit a bit late) at a total cost of £190. However, the fault still exists and I have been told that 5 hrs labour is required to check the wiring. Does this seem like a con? FYI the dealer is Dovercourt, Battersea and I have the feeling they are taking me to the cleaners here!
    Appreciate any advice at all!
    Alex
    Oct 2005
    Quote Originally Posted by alexed
    Alex
    Did you take the car in to have the initial fault fixed? They haven't done that, the problem still remains - you may have some comeback there.
    or was it taken in to have the ABS sensor replaced. They have done this, they did what you asked them to do.
    You say the fault still exists, have you hooked the car up to have the fault codes read? Do you have the codes that were pulled the first time, maybe you can post them up here?
    As for checking the wiring, I imagine it's a complex job for a specialist. Do you know any indy auto-electricians you can take it too?
    Jul 2006
    sure the codes are
    17978 ECU
    & 18057 data bus
    Basically it seems to be an electrical fault but could be anything from a wiring issue to an ECU fault to a connection fault. I don't want to fork out hundreds to have it fixed!
    If you need any more info from me then please ask... i appreciate your help!
    Oct 2005
    Ok, here's what the codes mean;
    17978 P1570 Contr.Module Locked
    and
    18057 P1649 Data Bus Powertrain Missing message from ABS Control Module
    It looks as though you may have some CCM problems - have you ever suffered damp in the car? I'm not too familiar with the Polo setup, so I can't say whether they have the same issues as the Passats, but the CCM can be found under the driverside carpet.
  1. POLO Abs Light
    By Adam in forum Polo - Derby - Lupo - Fox
    Last Post: 26-05-2014, 06:23 PM
  2. Polo 1.4 16V - EPC light, oil and service light issues
    By Trinster in forum Polo - Derby - Lupo - Fox
    Last Post: 19-08-2011, 08:57 PM
  3. polo gti abs warning light
    By gtifan in forum Polo - Derby - Lupo - Fox
    Last Post: 18-06-2009, 04:47 PM
  4. Serive light on 02 Polo
    By gingersteve in forum Polo - Derby - Lupo - Fox
    Last Post: 27-03-2007, 07:50 PM
  5. Polo ABS warning light
    By jeffbm in forum Polo - Derby - Lupo - Fox
    Last Post: 06-03-2007, 12:39 AM
