Thread: VCDS and high beam assist
Results 1 to 10 of 12
  1. VCDS and high beam assist
    Aug 2008
    Surrey
    Have completed the VCDS tips listed in the forum, thanks to all involved.. not tried the hidden menu though, sounds a bit iffy to me !
    The one I am having problems with is the high beam assist change. Modual 20 doesn't seem to exist. Although the car does have high beam assist..
    any ideas ?
    A7 Vorsprung Firmament Blue
    S4 Vorsprung Saloon Tango Gone
    A5 S line 50 TSFI Scuba Blue. Gone
  2. Re: VCDS and high beam assist
    46 Post(s)
    Are you sure it's not called something else or a different module number?
    Using genuine vcds, up to date? What year is your car?
  3. Re: VCDS and high beam assist
    Aug 2008
    Surrey
    Cars 2014, VCDS is new and genuine. Will have another look and see if I can see it in some other module. Thanks
  4. Re: VCDS and high beam assist
    Aug 2008
    Surrey
    It could be because the lights are adaptive with high beam. Not sure if anyone can confirm that ?
  5. Re: VCDS and high beam assist
    Feb 2013
    Gloucester
    57 Post(s)
    My wife's A5 has high beam assist with adaptive xenons and I changed her settings using module 20.
  6. Re: VCDS and high beam assist
    Jul 2012
    Hampshire, UK
    One of my friends has a MY14 A6, and whilst it definately has high beam assist, it doesn't have a module 20 or any other module dedicated to it. It's an S-Line with standard fit Xenons. We searched through many other likely modules, but didn't find anything that was related to HBA. Maybe one for the A6 forum?
    Mine - 2011 A7 3.0 TDi Quattro SE
    Hers - 2013 Mk7 Golf GT 1.4 DSG
  7. Re: VCDS and high beam assist
    Feb 2013
    Gloucester
    57 Post(s)
    I will double check mine for you later
  8. Re: VCDS and high beam assist
    Aug 2008
    Surrey
    Thanks for that... I've also looked around various modules and as you say cannot find anything related.
    Will try A6 boys and see if that brings anything
  9. Re: VCDS and high beam assist
    Feb 2013
    Gloucester
    57 Post(s)
    Ive checked and its defo module 20. if you cant find it, try typing 20 into the direct entry box and hit go. If it doesnt find it I can only assume you dont have HBA. Mine is the 4th down on the left in the image below.
  10. Re: VCDS and high beam assist
    Jul 2012
    Hampshire, UK
    It may not be so clear cut. I have LED headlights with HBA and module 20 as per M1tchy. My friend (MY14 A6) has Xenon headlights with HBA but no module 20. I can only assume it's part of another module, but we've struggled to identify which one.
  1. High Beam Assist Retrofit
    By Wicked Weasel in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-10-2014, 11:24 PM
  2. High-beam assist and speed question
    By nealeb in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-06-2013, 04:31 PM
  3. High beam assist
    By Ivor Bigun in forum VCDS - General Questions
    Last Post: 22-06-2011, 12:15 PM
  4. High Beam assist
    By sabingli in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-06-2011, 05:49 PM
  5. high-beam assist
    By tlionhart in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-04-2009, 07:25 PM
