Thread: Changing a MK4 Gaiter + (Gear Stick problem )
Results 1 to 9 of 9
  1. Changing a MK4 Gaiter + (Gear Stick problem )
    Sep 2007
    Looking for some info if you can help at all. I have a 2001 GOLF, that need its gaitor replaced. This is fine , my problem is I need to remove the gear stick top to get in on properly and i cant see how i can do this. There is a ring around the shaft of the stick, but no clips or any obvious way of releasing the top of the stick. Can it be done easily ??
    Cheers.
  2. Re: Changing a MK4 Gaiter + (Gear Stick problem )
    1840 Post(s)
    Lift the boot right up and you will find a crush clamp rather like a fuel hose clamp. Open up the crush section and the knob will come away, re crush the section to re-secure.
  3. Re: Changing a MK4 Gaiter + (Gear Stick problem )
    Sep 2007
    Hey thanks for the reply, just to be sure, your saying i uncrush the ring on the gear stick itself that i can see and recrush afterwards to secure. Just when you mentioned the boot i was a little off.
  4. Re: Changing a MK4 Gaiter + (Gear Stick problem )
    1840 Post(s)
    Yes, the crush clamp at the base of the knob under the boot. Open up the crush section with a flat blade screwdriver.
  5. Re: Changing a MK4 Gaiter + (Gear Stick problem )
    Sep 2007
    Cheers Crasher worked a treat, thanks for the info
  6. Re: Changing a MK4 Gaiter + (Gear Stick problem )
    Aug 2007
    Sorry to bring up an old thread but how much would this cost to get fixed at a garage? As i am non the wiser on replacing it myself
    I'm having trouble shifting into first and 2nd (however once i'm in those gears they work fine)
    Si
  7. Re: Changing a MK4 Gaiter + (Gear Stick problem )
    1840 Post(s)
    Can you describe the problem and also the car as the system changed in 2000 and there are different versions as well. PM me the cars reg to make life easier.
  8. Re: Changing a MK4 Gaiter + (Gear Stick problem )
    Aug 2008
    i was just looking at this thread as i am changing the gaitor on my new mk4 and it has been raised that you're having trouble getting into 1st and 2nd gears.
    i have the same problem and find it difficult at times to get into these gears. i was wondering what the problems could be??
    i have a V reg 1999, 1.4 mk4
    any help would be great
  9. Re: Changing a MK4 Gaiter + (Gear Stick problem )
    1840 Post(s)
    Anything from a simple alignment problem to a faulty clutch or even a faulty gearbox. I suggest you start a new thread over this and go into some depth about the problem.
  1. Changing cv joint / gaiter
    By MartinPCWard in forum Passat - Archive Topics
    Last Post: 07-01-2008, 08:13 PM
  2. Gear Gaiter
    By Brekka in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-07-2007, 11:05 AM
  3. B5 replacing the gear stick gaitor?
    By jedi172 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-07-2007, 04:22 PM
  4. A3 removal of Gear stick 1.8 20vT 97 p
    By chocoboy in forum Audi A3 - Archive Topics
    Last Post: 26-02-2007, 01:23 PM
  5. Gear Changing Problem On Mk.3 Golf
    By mac500 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-02-2007, 09:02 PM
