Thread: Windows 7 BSOD - Unmountable Boot Volume
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 78
  1. Re: Windows 7 BSOD - Unmountable Boot Volume
    #21
    May 2011
    london
    Sorry to here about your busted drive. First off western digital have a great warrenty service, just go online and enter serial and it will tell you straight away if its in warranty. They will even send you a replacement before u send them the dud. I have used this service a few times and was very impressed no need for receipt or proof of purchase. Might be worth a try. On another note I have been using avast for 10 years or so and have never had problems with it. Currently on 5 pcs at home with no issues. A few years back I had raptor installed which is a chat program combining all the common ones such as msn icq etc etc. This was blue screening my pc all the time. Uninstalled and never blue screened again. So i guess software conflict somewhere. Maybe with avast.... Anyway good luck get the data off and re install.
    Sent from my HTC One X using Tapatalk 2
  2. Re: Windows 7 BSOD - Unmountable Boot Volume
    #22
    Oct 2005
    Quote Originally Posted by utensil999 View Post
    There is no warranty with WD, the HDD is effectively an OEM drive as it was part of a Dell laptop. The warranty is with Dell and has, as per Chris's posts above, expired.
  3. Re: Windows 7 BSOD - Unmountable Boot Volume
    #23
    Sep 2009
    London/Bucks England
    Sounds like the drive is dying, chkdsk my falsely report bad sectors if the motor is failing. The drive motors and or reading heads can fail early from time to time and cause a de-sync/corruption of info hence the bluescreens.
    It will run ok in a caddy. Alternatively if your motherboard can disable the SMART error report feature then this may be you some more hours of non-caddy use. Also from experience, if you keep trying to boot a dying drive, it may corrupt the boot sector and then eventually stop responding completely. I've had it happen to about 3 HDD's over the years. My best advice would be to get a new drive, caddy this one and back up what you can before the drive goes poof.
    You can send it off for 'repair/recovery' but do you have anything worth saving on it that will cost that amount is the question. In the mean time you will still need a new drive anyway.
    151 PS @ 3800 rpm 1.6 8V MPi - 31.5mpg urban <-- Happy days
    123k On the clock and counting. (25k on the block)
    I need all your V-Powers.
  4. Re: Windows 7 BSOD - Unmountable Boot Volume
    #24
    46 Post(s)
    Right ok, been out all day and left the laptop to run. Something must've happened/restarted as it's back hanging at the recovery screen.
    Not sure if the chkdsk ran or not. Everything valuable is backed up in 2 places, emails are fine and got my Firefox bookmarks back so that's all I'm really worried about.
  5. Re: Windows 7 BSOD - Unmountable Boot Volume
    #25
    Oct 2005
    Find() and download a copy of Hiren's Boot CD , burn it to a CD and boot from it, up to you which machine you use but I'd go with the Dell laptop just in case you select the wrong drive in the next few stages
    Again, don't do anything unless you're 100% sure - you could potentially kill the drive completely.
    Find the HDD Diagnostics menu and do the following;
    DLGDIAG will verify the HDD's status and WDDLGT will hopefully scan and fix any errors - if it can't it'll let you know why.
    If they don't work, you can move on to the harder stuff.
    MHDD and DRevitalize will both attempt to locate and fix any mechanical defects.
  6. Re: Windows 7 BSOD - Unmountable Boot Volume
    #26
    46 Post(s)
    DLGDIAG froze and didn't finish. Said it would take 5 mins, got dinner, came back after 30 mins and the Abort function didn't work.
    Couldn't see anything inside the WDDLGT which would scan, only setting up a new drive and view info.
    DRevitalize is currently running, albeit slowly.
  7. Re: Windows 7 BSOD - Unmountable Boot Volume
    #27
    New Forest
    80 Post(s)
    If you've got everything you need off the drive, why not format the disc and re-install Windows?
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  8. Re: Windows 7 BSOD - Unmountable Boot Volume
    #28
    46 Post(s)
    Surely as it's a drive fault not OS the issue will still be there?
    12 hrs in and were a 1/3 of the way through
  9. Re: Windows 7 BSOD - Unmountable Boot Volume
    #29
    New Forest
    80 Post(s)
    Not if the bad sectors are maked as such and therefore marked not for use.
  10. Re: Windows 7 BSOD - Unmountable Boot Volume
    #30
    46 Post(s)
    Quote Originally Posted by ragebe View Post
    I'll probably just end up keeping it in the caddy to be honest after the test finally finishes and get another. Don't think I could trust it again.
    However, Sam's test has proven useful and at 24hrs were 2/3 of the way through and found some(!) bad sectors. I assume since it's 'recovered' them they've been fixed? Hopefully this lets me boot up.
  1. electric windows/boot lock/fuel flap failure
    By boidy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2011, 03:09 PM
  2. Windows opened by boot
    By Padwick in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-06-2010, 07:54 PM
  3. Please Help Electric windows+interior lights+boot
    By kaseeta in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-04-2009, 09:12 AM
  4. Please Help Central locking, Electric windows and boot light.
    By LewisFTW in forum Audi A3 - Archive Topics
    Last Post: 10-01-2009, 12:17 PM
  5. Unlock the boot and the windows open?!
    By The Stagg in forum Passat - Archive Topics
    Last Post: 06-01-2007, 11:55 PM
