Thread: Poorly bug
Results 1 to 9 of 9
  1. Poorly bug
    Sep 2007
    Essex boy in Suffolk
    So my wife tells me the other day that she has some lights on her dash, unfortunately she could not tell me when they came on or what was happening at the time
    I've scanned it a got these faults, looks like the engine has an intermittent short somewhere on a supply line which worries me a bit (don't like shorts on main power supply wires, especially with my wife and son in it).
    Does anyone know any common places where any shorts can occur or has seen this before?
    VCDS Version: Release 11.11.6
    Data version: 20121223
    Saturday,02,November,2013,16:07:42:27548
    Chassis Type: 1C - VW New Beetle
    Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
    VIN: Mileage: miles
    Address 01: Engine Labels: Redir Fail!
    Part No: 06A 906 032 GM
    Component: 2.0l 2V AGW 4095
    Coding: 00001
    Shop #: WSC 00066
    VCID: 6FE777B12DF69060C91
    WVWZZZ9CZ2M606174 VWZ5Z0Z6032145
    16 Faults Found:
    16804 - Catalyst System; Bank 1
    P0420 - 35-00 - Efficiency Below Threshold
    16645 - Fuel Injector #1 (N30)
    P0261 - 35-10 - Short to Ground - Intermittent
    16651 - Fuel Injector #3 (N32)
    P0267 - 35-10 - Short to Ground - Intermittent
    16654 - Fuel Injector #4 (N33)
    P0270 - 35-10 - Short to Ground - Intermittent
    16648 - Fuel Injector #2 (N31)
    P0264 - 35-10 - Short to Ground - Intermittent
    17833 - EVAP Purge Valve (N80)
    P1425 - 35-10 - Short to Ground - Intermittent
    17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
    P1117 - 35-10 - Short to Ground - Intermittent
    17922 - Intake Manifold Valve 2 (N261)
    P1514 - 35-10 - Short to Ground - Intermittent
    17843 - Secondary Air Pump Relay (J299)
    P1435 - 35-10 - Short to Ground - Intermittent
    16502 - Engine Coolant Temp. Sensor (G62)
    P0118 - 35-10 - Signal too High - Intermittent
    17523 - Oxygen (Lambda) Sensor Heating: B1 S1
    P1115 - 35-10 - Short to Ground - Intermittent
    17606 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2
    P1198 - 35-10 - Electrical Malfunction - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-10 - - Intermittent
    16685 - Cylinder 1
    P0301 - 35-10 - Misfire Detected - Intermittent
    16686 - Cylinder 2
    P0302 - 35-10 - Misfire Detected - Intermittent
    17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
    P1296 - 35-10 - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
    Part No: 1C0 907 379 E
    Component: ESP FRONT MK60 0104
    Coding: 0019458
    Shop #: WSC 00066 000 00000
    VCID: 2C5DA0BD8C60AB78AC3
    No fault code found.
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 A
    Component: 1T AIRBAG VW51 0D 01
    Coding: 12628
    Shop #: WSC 00066
    VCID: 22414E85AEA46D0816F
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    49-10 - No Communications - Intermittent
    Address 17: Instruments Labels: 1C0-920-x4x.lbl
    Part No: 1C0 920 920 CX
    Component: KOMBI+WEGFAHRS. M73 V08
    Coding: 01412
    Shop #: WSC 00098
    VCID: 75EB45D94FAAAAB003D
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN V082
    Coding: 00006
    Shop #: WSC 00000
    VCID: F0E5F4CDB0C80F9850B
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 F
    Component: 2Q Komfortgerát HLO 0004
    Coding: 00064
    Shop #: WSC 00066
    VCID: 3A7196E5263405C82EF
    Subsystem 1 - Part No: 1C1959801A
    Component: 2Q Tőrsteuer.FS KLO 0002
    Subsystem 2 - Part No: 1C1959802A
    Component: 2Q Tőrsteuer.BF KLO 0002
    2 Faults Found:
    01131 - Control Circuit for Turn Signals
    25-10 - Unknown Switch Condition - Intermittent
    00945 - Crash Sensor (G190)
    29-00 - Short to Ground
    Address 56: Radio Labels: 1J0-035-18x-56.lbl
    Part No: 1C0 035 186
    Component: Radio BNO 0005
    Coding: 00401
    Shop #: WSC 00066
    VCID: DBBFB361494E9CC0959
    All help and suggestions appreciated
    Graham
    Still pretending to know stuff.
    Golf 6 .:R
    Corrado 20vT - BBS RCs, Leather, Bremo's, TFSI and DSG
  2. Re: Poorly bug
    Aug 2011
    Meath
    Clear all the codes then do a stop/start about 10 times. you can do this over a day or 2 then rescan. Those codes could be years old. You can check code meanings here Ross-Tech Wiki
  3. Re: Poorly bug
    Sep 2007
    Cleared codes yesterday and told the wife to tell me if the light comes on again during the week.
    Codes were cleared a while ago when the engine speed sensor failed so they are all new which is why I suspected a supply cable (Lots of shorts to ground listed). My other worry is the ECU has an intermittent fault
    Graham
    Golf 6 .:R
  4. Re: Poorly bug
    Aug 2011
    Meath
    Could be a battery problem is it in good condition. Voltage surge?
  5. Re: Poorly bug
    Sep 2007
    hmm, possible, it is about 4/5 years old
    She now tells me it has occasional problems starting where it turns over but wont fire for a while then starts to fire but wont start
    Graham
    Golf 6 .:R
  6. Re: Poorly bug
    Aug 2011
    Meath
    Any of those tyre/battery or Halfords places will test it for free. 5 years is PDG for a battery
  7. Re: Poorly bug
    Sep 2007
    Gotta be worth a test
    Graham
    Golf 6 .:R
  8. Re: Poorly bug
    Sep 2007
    Today it cut out in traffic, so my wife got to the kerb, left it for a min then tried to re-start it. Luckily it started first time but the dash light was up again.
    Scanned it again when I got in and found the same engine faults as above.
    So, I have now looked at the circuit diagram and it would seem that all supplies lead back to the fuel pump relay which in turn is supplied by a 50A fuse on top of the battery.
    The fuse is fine so it leads me to believe the problem could lie with the fuel pump relay, but that could be the connections to it, the switched supply from the ECU or the wire from the fuse.
    Has anyone else had relay troubles like this?
    Graham
    Golf 6 .:R
  9. Re: Poorly bug
    Sep 2007
    Had a chance to do some work on this today, replaced the fuel pump relay and took it out.. 50miles so far without missing a beat, fingers crossed I was right
    Graham
    Golf 6 .:R
    2 0 0
  1. poorly A3 1.8T
    By a3_1.8_tish in forum Audi A3 - Archive Topics
    Last Post: 05-04-2009, 09:32 PM
  2. Please Help Poorly 1.8T
    By richjthorpe in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-09-2008, 05:09 PM
  3. very poorly golf
    By Cassius in forum Golf MK4 - 1999 - 2004
    Last Post: 01-04-2008, 07:34 PM
  4. Poorly Lupo Needs Help
    By Porkus_Maximus in forum Polo - Derby - Lupo - Fox
    Last Post: 22-03-2008, 08:15 PM
  5. poorly s2
    By fraze in forum Archive posts
    Last Post: 04-07-2007, 10:16 PM
