Thread: Thinking of buying. Changes from 2007 on
  1. Thinking of buying. Changes from 2007 on
    Jan 2006
    Southampton
    Right I fancies a Phaeton. I'm probably looking at 3.0 diesel. For the money I'm spending I'm looking at around an 07 car but I understand they did an update that year. What were the changes? are they easy to spot? Was any done to improve reliability? I also understand a mod was done to the 3.0lt engine. Something to do with injectors failing to shut and causing smoke and timing chain rattle from cold start. What year did these improvements happen?
    Sorry for all the questions just don't want to get lumped with any big bills just after buying. I'll be looking at cars with 60-80k miles on. Apart from the normal wear and tear items is there any other issues at that mileage?
    Cheers all
    Phaeton 3.0 LWB
    Lotus Carlton
    If you have to ask you wouldn't understand
  2. Re: Thinking of buying. Changes from 2007 on
    46 Post(s)
    The engine is mostly shared with Audis, and they fixed most things by 2007 so you should be fine. Older cars had problems with chain rattles.
    If you're buying from a dealer you will have a minimum 3 month unlimited mileage warranty so should anything go wrong you'll be covered.
    Have a look at the old brochure here - http://www.volkswagen.co.uk/used/old-brochure
    Remember they're not a easy car to run, you'll struggle to see 40mpg on a long run and just because the car is cheap(er) than it was new, you'll still have the running costs of a £50k+ car.
  3. Re: Thinking of buying. Changes from 2007 on
    Jan 2006
    Southampton
    Cheers,
    This wee runabout comes home next Tuesday
    Phaeton 3.0 LWB
    Lotus Carlton
  1. Thinking about buying new A6
    By Doctee in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 15-11-2011, 05:40 PM
  2. thinking of buying
    By gizmobell in forum Leon
    Last Post: 22-02-2010, 03:46 PM
  3. Thinking of buying a B6 A4
    By benjie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-11-2008, 09:36 PM
  4. Thinking of buying a T4...
    By novo in forum The Commercial Range
    Last Post: 24-12-2007, 10:43 AM
  5. Thinking about buying new A6
    By in forum New Member Introductions
    Last Post: 01-01-1970, 01:00 AM
