Thread: Is my A/C compressor shot?
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
  1. Is my A/C compressor shot?
    Jun 2010
    Maynooth Ireland
    Ive a 06 1.9 TDI Passat. When the a/c is set to Lo and Econ off the car struggles to blow cold air. I've had the system topped up and it holds pressure. Accessing the climatronic diagnostics and watching the coolant pressure it struggles to get above 7/8 bar but can sometimes get to 16 and stay there for a few minutes resulting in a nice icy blast! I've scanned using VCDS and no faults are shown for HVAC.
    See the screenshots below with temp set to Lo from VCDS and am starting to think it is the compressor it's just the intermittent ability to build pressure confuses do they fail in this fashion?
    Thanks in advance for any help!
  2. Re: Is my A/C compressor shot?
    Jun 2010
    Maynooth Ireland
    Was out today and using the climatronic diagnostics it was showing over 24 bar in pressure at times with no cold air and falling back to 8. Temp was set to Lo. Anyone got any ideas whats at fault?
  3. Re: Is my A/C compressor shot?
    DSG4ME Guest
    Quote Originally Posted by n0brain3r View Post
    See if turning it hot makes it get hotter, if it doesn't it's got to be either the swichgear or maybe the canbus unit.
    I notice you're not getting any fresh air intake, I wonder if the pollen filter or the bulkhead vent is blocked.
  4. Re: Is my A/C compressor shot?
    Jun 2010
    Maynooth Ireland
    Quote Originally Posted by DSG4ME View Post
    Turning the heat up does make it hotter. I'll checks the vents but I think they're ok pollen is the one under the glovebox right? Shouldn't I still get a temp though or does it require airflow?
  5. Re: Is my A/C compressor shot?
    Sep 2007
    South Manchester
    I wonder if you G65 sensor is playing up
    VW Passat Estate 2.0 TDI DSG in Silver 2006
  6. Re: Is my A/C compressor shot?
    Jun 2010
    Maynooth Ireland
    Ok I left the diagnostics on again today and switched between compressor pressure and Evap temp. Pressure eventually got up to 17/18 bar and Evap temp 10-13 c. Air was cool but not cold. Gazza just wondering what make you think it's the sensor? Does anyone know what the pressure should peak at?
  7. Re: Is my A/C compressor shot?
    Sep 2007
    South Manchester
    http://www.volkspage.net/technik/ssp/ssp/SSP_208_d1.pdf
    It was just a thought. Above article maybe helpful. I actually bought a sensor when I had a recent problem which was of my own making.
    Ps it's for sale. Hope you get sorted
  8. Re: Is my A/C compressor shot?
    Jun 2010
    Maynooth Ireland
    Had a quick read of the pdf here in work. I think I'll need to study it more closely later! What was your problem if you don't mind me asking?
  9. Re: Is my A/C compressor shot?
    Sep 2007
    South Manchester
    Inadvertently had removed a fuse following sticking a screwdriver in the wrong place when putting interior LEDS in. Then my partner took the car so didn't realise there was anything wrong till a few days later. As a result I bought a new G65 but realised eventually that it was my error but in the meantime got a free ac refill at Kwik fit and bought myself VCDS. Within my research I found out a bit about the G65 & it's function hence why I think it could be your problem. Happy to sell t a forum member at cost price.
  10. Re: Is my A/C compressor shot?
    Jun 2010
    Maynooth Ireland
    Ok so as I understand it the G65 sensor monitors refrigerant pressure, fan activation and speed and the indirectly controls the compressor clutch. From reading the pdf and the freeze frame above a couple of things stand out or maybe it's nothing!
    Pressure 6-8 bar is almost ambient so compressor is doing nothing yet .8amps is the clutch fully engaged.
    If the g65 is faulty I can't trust pressure readings (They're derived from it right?) yet with the clutch fully engaged no cooling is occurring but this could be down to the low fan(9.6% vs 0% requested) speed not cooling the condenser enough so that the refrigerant ever liquifies preventing adequate cooling.
    This may explain why after a period of driving it improves slightly I'll check the fan operation and condenser condition tomorrow or am I just making the pieces fit!!
    How much for the sensor btw?
  1. Is my Ac compressor clutch shot?
    By Google44 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-05-2013, 03:25 PM
  2. Allroad air compressor vs. A6 rear self leveing compressor
    By g.suggy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-06-2012, 11:00 AM
  3. Attention This guy needs to be taken outside and shot.
    By Hex69 in forum Chat - Completely Off Topic
    Last Post: 24-09-2009, 04:39 PM
  4. Engine shot?
    By ccfc1972 in forum Audi A3 - Archive Topics
    Last Post: 06-06-2008, 08:48 PM
  5. A long shot but.......
    By RobDob in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-03-2008, 04:47 PM
