Thread: Golf mk5 GT TDi 170 engine management light
  1. Golf mk5 GT TDi 170 engine management light
    Mar 2013
    Newton aycliffe
    Hi all. Looking for a help. My 58 plate golf has its engine management light on. Confused though because the car runs spot on and pulls like a train as always. I've even run it on the motorway in case it was a dpf issue. Ive looked around the engine, even had pipes of the turbo to see if theres an issue there but cant see any issue. So im assuming its electrical maybe air mass sensor or egr?? anybody had this experience? It's got almost 72k miles on it. Thanks.
  2. Re: Golf mk5 GT TDi 170 engine management light
    Nov 2009
    46 Post(s)
    You need a fault code scan done.
    Have you checked if your injectors are subject to a recall?
    Ring VW CS on 0800 333 666
  3. Re: Golf mk5 GT TDi 170 engine management light
    Mar 2013
    Newton aycliffe
    Yea I guessed I'll have to get it diagnosed, just people my have had similar issues. It was a former company car through arval, which is what made me buy it with its full vw service history and had been well looked after. So I'd guess its had a recall but i'lll call that number as well. Thank you
  4. Re: Golf mk5 GT TDi 170 engine management light
    Nov 2009
    46 Post(s)
    Without a scan we will be guessing possible faults all night long.
    Try the number anyway, no harm in ringing a free number
  5. Re: Golf mk5 GT TDi 170 engine management light
    Leics
    You will have checked your air filter is not clogged with dirt won't you? If that is blocked a new air filter should cure it. Won't take you long.
  1. MK5 Golf Tdi 140/170 worthy successor to the MK4 Tdi 150?
    By iworld in forum Golf MK5 - 2004 - 2009
    Last Post: 02-06-2010, 11:26 PM
  2. Golf Mk5 GT TDI (170) Starting Problems
    By craigrule in forum Golf MK5 - 2004 - 2009
    Last Post: 11-01-2010, 11:34 AM
  3. 170, DPF and Engine Management light
    By shudman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-04-2009, 12:02 PM
  4. Question engine Management light on golf gt tdi
    By jimbob in forum Golf MK4 - 1999 - 2004
    Last Post: 18-11-2008, 08:40 PM
  5. golf engine management light problem
    By HUTCH in forum Chat - Completely Off Topic
    Last Post: 07-11-2006, 07:04 PM
