Thread: A4 Avant rear wiper 'squirter'\water jet fuse
  1. A4 Avant rear wiper 'squirter'\water jet fuse
    Nov 2008
    2
    My A4 B7 rear wiper has been acting erratically recently so, having followed a thread or two on here (thank you to those who've posted "How to's..." very useful) I've removed it and sure enough there's a leak somewhere (probably where the nozzle joins the motor I think) and the PCB in the motor is damp. I think it's probably redeemable so will try to resurrect it and fix the leak.
    However, while I do this the motor will likely be out for a few days and I want to stop myself being an idiot and absent mindedly trying to clean the rear windscreen while driving as all this will do is squirt water around the boot at the moment! Does anyone know the which fuse controls the rear 'squirter'\water jet? I can't find it in the fuse list. The manual tells me that there's one for the 'wiper system' (36) and another for the 'pump for windscreen washer' (37) but none listed for the rear pump and I'm guessing it must be different as the rear 'squirter'\water jet pump is not activated at the same as the front one.
    Has anyone come across this before and knows which fuse it is?
    Sqwim
  2. Re: A4 Avant rear wiper 'squirter'\water jet fuse
    Malvern
    7
    I don't know the answer to your question, but in your place, I would stuff a drill bit of suitable diameter in the end of the pipe to conain the flow!
    By the way, the expression "squirter" is fine, but I tend to call this whole device a bidet, for obvious reasons!
    Good luck with the Lazarus attempt.
  3. Re: A4 Avant rear wiper 'squirter'\water jet fuse
    Nov 2008
    2
    Thanks, I may well have to do something like that as I can confirm that the necessary fuse is #37. Unfortunately this means that the front 'squirters'\water jets won't work either!
  4. Re: A4 Avant rear wiper 'squirter'\water jet fuse
    Oct 2010
    Glenrothes,Scotland
    0
    Hi Sqwim
    I had the same problem with an erratic rear wiper motor. I also had a leak at the connection to the motor with water pouring everywhere. My motor was perfect but the mechanical winding side was gubbed. I stripped my motor unit and found that the cogs inside the wiper unit had worn and were connecting sometimes and sometimes not. Unfortunately it was a new motor unit for me. Easy to replace and cost was 79.99 for a new unit from Lincon AUDI with a 2 year warranty. Got new hose and fittings from them also for 6.50. All good now and running great again. You dont realise how much you need that rear wiper. Not sure if you have resolved your problem but thought I would post anyway.
  5. Re: A4 Avant rear wiper 'squirter'\water jet fuse
    Nov 2008
    2
    Thanks. I am indeed all sorted now, a new motor was required as the PCB had corroded sufficiently badly that my attempts to resurrect made it worse! I thought the issues was the connector between the hose and motor but the new motor assembly also gets a *little* bit damp there too when squirter is used. My thoery now is that because the wiper was blocked at the nozzle end, my repeated efforts to clear by squirting probably caused sufficient water to leak out within the motor housing itself.
  1. Rear wiper / jet
    By Mattwarner1979 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-04-2011, 07:00 PM
  2. Question Rear washer jet, Avant 80 tdi
    By palaemon in forum 80 - 90
    Last Post: 07-02-2010, 03:14 PM
  3. Please Help rear wiper jet blocked, no prbs with hose
    By anopinion in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-05-2009, 07:05 PM
  4. Question wiper linkage and rear washer jet spray
    By JarvisTheCocker in forum Ibiza - Cordoba
    Last Post: 01-03-2009, 09:26 PM
  5. avant rear water jet
    By bez101 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-03-2008, 11:03 AM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
