27-01-2013,08:01 PM
Does the PC work immediately after this? i.e. if you power down and reboot, does the display work and die in a similar way after a similar amount of time or does it require a waiting time before it fires up again?
If straight away it's unlikely to be heat.
...Also worth noting that the latest Ubuntu linux has a known issue with this sort of freezing up. Not sure if this is the same with Debian as I haven't used version 12.
Current Car(s): 2003 Audi A8 4.2Q, TOP SPEC (Adaptive Cruise, Adaptive Cornering Lights, Bose, Voice Command, Extended leather including headlining, Tyre Pressure Monitoring......)
Past Audi's: 2005 Audi A8 3.0TDI Quattro 2x 1999 Audi A8 4.2 Quattro, 2001 Audi A4 2.8 Quattro, 2x Audi A4 1.9TDI's (1999/2000), 1983 2.1 5 cyl Audi Coupe GT FI
