Thread: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 65
  1. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #41
    Oct 2014
    Ljubljana
    Thanks Martin for your detail manual. It was very helpful for me I solve my problem only by changing switches. But today get new error ""move steering wheel" . I check the steering lock module and I see that can't put up the part A because part B was blocking part A.
    What is part B function?
    I put part B out and it seems ok.
  2. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #42
    Norfolk
    Did you lose a spring when you took it apart.
  3. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #43
    Oct 2014
    Ljubljana
    No, I did not lose the spring. I have all parts. I did not install part b an spring.
    Did you now what is part B function (purpose)?
    Thanks.
  4. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #44
    Norfolk
    Part 'b' is the lock peg. Without part 'b' you do not have a lock.
  5. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #45
    Oct 2014
    Ljubljana
    Thanks Martin,
    I still not understand this fully.
    When part B is in lock position (on the left) (released spring), what make part B unlock it again?I don't see that motor can unlock part b (to right position).
    Thanks for replay
  6. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #46
    Norfolk
    Motor locks and unlocks by moving peg. Micro switches control position.
  7. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #47
    Jan 2015
    Nottingham
    Quote Originally Posted by reddevil7 View Post
    i would just like to add to this thread i had my car fixed 18 months ago at the cost of 150 quid they had the steering column off inside 20 mins did there magic on the workbench and car was ready to go after an hour top class fix they recently done my glowplugs as well they have the software to do all is required on everything vw i recommend these guys very highly so if you can get your car to northampton they will fix it they have had people come from as far away as ireland so if u need any more info drop me a line and i will pass on there mobile number all the very best fellow dubbers reddevil7
    hi can I have the number please cos I'm struggling to get one my car got same problem I need to get it checked with these guys please much appreciated thanks
  8. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #48
    Sep 2008
    SE London
    Quote Originally Posted by alan88 View Post
    If you’re anywhere near Northampton, many have used this firm to fix their steering lock problem:
    PASSAT B6 (3C)DIFFICULT START,steering lock.., | eBay
  9. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #49
    Norfolk
    Some people are "repairing" the steering lock by disabling it. This is now an MOT fail if the tester spots that the lock isn't working, so it is worth checking that a repaired lock still works.
  10. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #50
    Mar 2015
    Dallas TX USA
    Well good evening from Dallas TX in the U.S. I just joined this site as it seems that you guys actually seem to fix your cars and not just take them to the ***********. I just sent my money to have full access to Martin's website as at the rate my wife's 2007 Passat Wagon 2.0t is breaking stuff I am going to need it. We have not had it a year yet and the downpipe separated from the flange where it bolts to the turbo thus running an open and very loud exhaust (took it off and had it welded up), while doing that I found the inner boot for the right side (passenger side over here) inner cv boot was torn so replaced axle, fixed one oil leak at oil filter housing, I replaced the timing belt, idler, belts and water pump three months ago, and now the Sanden AC compressor has eaten itself (bought a new replacement to put in with all associated parts), front rotors are warped (have them too), the m80 purge valve is bad (have that), front lower arm bushings are worn (have those too), the drivers side floorboard has water under it (need to figure that out, have already blown sunroof drain hoses out) and just today the steering wheel lock light and message came on. This car only has 98,000 miles. I have never had a vehicle with issues like this.
    However, the question I have is that if I buy a replacement steering column lock 3C0905861J and have a vag com 12.12.0 can I just reprogram the keys to work or does it have to be done by Volkswagen? I swear having this car is like having a second job. I had to buy the Vag com just to keep up with codes that pop up. Volkswagen had a recall on this same issue in the US, but for whatever reason the recall was time limited and time is now up. If I cannot re program the keys to the steering column lock or the steering lock to the car then I am just going to clean out the switches and hope for the best. My wife is really starting to dislike the car and after all of the problems it has had I cannot say that I blame her. Thanks for the help.
  1. Steering Lock See Workshop and dealer problem
    By UkMark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2020, 08:30 PM
  2. Friendly Midland Dealer for key recode
    By Thacker in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2011, 07:04 PM
  3. 2008 Audi A3 Wing mirror cheap fix anyone?
    By cunny678 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-01-2010, 02:15 PM
  4. 2003 abs & steering angle recode need help
    By deutsch in forum VCDS - General Questions
    Last Post: 28-11-2009, 12:34 AM
  5. Quattro rear ABS sensor cheap fix?
    By Strange Fish in forum New Member Introductions
    Last Post: 13-09-2008, 02:53 PM
