Thread: How to remove stone chips?
Results 1 to 10 of 14
  1. How to remove stone chips?
    macc70 Guest
    Hi after doing a couple of long motorway trips I arrived home to discover loads of chips and scratches on the front of my golf. I would appreciate any advice you have to getting rid of these. The chips although small are deep whereas the scratches are fine and only surface marks. What do I need to buy to get the best results. the market is awash with products and choosing the best and easiest to use is a bit of a puzzler
    many thanks for any advice you have
  2. Re: How to remove stone chips?
    Oop a gum tree
    198
    Not the answer you want but...
    Get it re-sprayed.
    Waxes will only very slightly mask the chips.
  3. Re: How to remove stone chips?
    macc70 Guest
    Many thanks BigCol your the second person to suggest that. It does seem to be the best solution as the car is new and the paint will be easier to match than it would be if on an older car
  4. Re: How to remove stone chips?
    Oct 2006
    CENTRAL SCOTLAND
    1
    Every car is going to get stone chips. Even with the protective films, you will get stone chips.
    Get yourself the touch up paint from the dealer. Don't use the brushes in any touch up job as you don't want to leave brush strokes.
    Using a cocktail stick tip, carefully dab a little of the paint into the chip. Leave for about 45 mins to dry a bit. Then add some more. Over time you want the paint to sit proud of the panel. This then gets wet-sanded down to the panel level. Lots of sanding scratches appear but then get polished out by dual-action or rotary polisher.
    We can't respray our cars every time we get chips, well I can't! A good detailer in your area can do this for you at approx £20-£30 an hour.
    If you have the money to respray all the time, then lucky you!!
  5. Re: How to remove stone chips?
    macc70 Guest
    Many thanks for the response especially for the cocktail tip I will give it a go
    I have been quoted £45 to fill in the chips on the front and sides which is OK if you dont get anymore for a while but sods law says the very next day ..................
  6. Re: How to remove stone chips?
    Newbury
    3
    Looking at sorting some of my stone chips on the bonnet too.. So thanks for the advice..
    With respect to a rotary polisher, does anyone have any recommendations with respect to which on is best / best value etc?
    Cheers.
  7. Re: How to remove stone chips?
    Oct 2006
    CENTRAL SCOTLAND
    1
    You would probably be better off with a dual action polisher for the job. It's job will be to sand out your sanding marks from wet-sanding. A DA is adequate for this. No need for a rotary as they have so much torque and require a good bit of training to use them safely and effectively. I'm not sure of the value of the £30 on sale a Halfords, I think they're ok for applying products like cleansers and sealants and the like, rather than removing wet-sanding marks - you need a range of speeds.
    The dual action polisher/sander that has been hi-jacked by the car enthusiasts is the Porter Cable 7424, now superceded by the Ultimate Detailing Machine
    (UDM). Both are available from Autopia is USA but will need a transformer. Will soon be available as 230V UK version so worth waiting really. It's the machine to have if you care for your car. Machine polishing guide will be up within the next week or so.
    To have a look anyway, here's the Autopia link:
    http://www.autopia-carcare.com/
    Stone chip repairs, no matter how good, will always be visible upon close inspection and only a respray will give a seamless job. Worth bearing in mind. But a good enthusiast job to get into if you have an appropriate polisher.
    Hope this helps.
    JOHN
  8. Re: How to remove stone chips?
    Newbury
    3
    Thanks for the info... When I get my home internet connection up and running I will look into what you have told me.
    Cheers!
  9. Re: How to remove stone chips?
    0
    Try this,
    lollypop stick
    small piece of chammy leather
    "T" cut liquid
    coloured polish wax (matching your car)
    cocktail stick
    Paint aerosol because you get more and because you can brush or spray.
    PROCEDURE.
    Remove dirt/grime from around chipped area.
    Spray a little paint into the paint can cap
    Using a cocktail stick dab paint into chipped area so that it is slightly proud of the surface.
    Allow to dry for a couple of hours but not so long that the paint is too hard. It must be set, but still a little soft. Check the paint left in the cap to see how soft it is.
    Now mix a little T cut and the coloured polish together in a small bottle cap or bigger.
    Wrap the chammy around the lolly stick
    Dip the chammy into the polish mix
    Using the end of the lolly stick or the flat part of the lolly stick,Carefully cut/polish the mound of paint untill it is as flat as the normal surface. You may need more than one coat.
    Because it is still fairly soft it should rub down quite easily.
    Once finished, polish the area with the coloured wax and step back in amazement.
    You'll never beat a respray but with patience it won't be a bad job.
    Remember.....PATIENCE.
    Remember........DON'T LET THE PAINT SET TO HARD BUT IT MUST NOT BE TOO SOFT
    Hope this helps
    MR RUGBY
  10. Re: How to remove stone chips?
    Sep 2007
    0
    There is a UK franchise called Chips Away which does stone chip repairs, I would do a link but I'm not 100% certain whether I'd get a bo**ocking for it , so just Google (am I allowed that? ) "Chips Away".
  1. Mod Chips
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-08-2007, 02:58 PM
  2. S3 and chips please...
    By rdj_s3_quattro in forum Audi A3 - Archive Topics
    Last Post: 19-07-2007, 11:17 AM
  3. Music... Complete Stone Roses... Gig.. Fancy it??.
    Last Post: 28-06-2007, 12:35 PM
  4. Stone cold bottom rad hose...
    By colifeashots in forum Passat - Archive Topics
    Last Post: 24-02-2007, 04:16 PM
  5. stone chip repair
    By tony_anon in forum Audi A4 - Archive Topics
    Last Post: 28-01-2007, 09:43 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
