Thread: Passat brake light bulb replacement
Results 1 to 8 of 8
  1. Passat brake light bulb replacement
    Aug 2006
    0
    I've got a 2004 Passat Estate and am trying to replace a brake light bulb. I used to own a Golf and the plastic bracket that held all of the light bulbs was held in with 4 clips and was easy to remove by squeezing them together. Now on my Passat there seems to be no way of getting this light bulb bracket out. There are a couple of clips that look like the old Golf ones but they don't seem to have any effect. Anyone got any ideas?
  2. Re: Passat brake light bulb replacement
    May 2007
    0
    Hi Nobby,
    i have a similar problem, again it took me a while to get the light cluster out on the rear nearside of the car. i have a 2002 estate and i too tried to replce the brake light bulb. The cluster itself will come out using the 2 clips you mentioned, i does need a little bit of teasing but you will get there in the end.
    HOWEVER, i've managed to replace the 2 middle bulbs for the brake light but upon replaceing the unit have now lost power to ALL the lights on the rear nearside!
    I've no idea if this is due to a blown fuse or something more serious?!?! So i would proceed with caution, i'm actualy debating taking the car to VW to sort it unless anyone on the forum can help?
    cheers
    Feegs
  3. Re: Passat brake light bulb replacement
    Jun 2006
    UK, Registered Homeless
    3
    It's the cold weather making the plastic stiff so it doesn't yield. You are meant to bend the clips inwards, and wiggle the bulb holder and it should withdraw. You may as well replace all the bulbs while out. Also, check carefully the pin alignment, I think there is a difference between 4 and 5w bulbs or something, any way the ones I had initially were wrong.
  4. Re: Passat brake light bulb replacement
    May 2007
    0
    Hi Snapdragon,
    Thanks for that advice. I'm just wondering what you meant by the pin allignment of the bulbs? The replacement's i've bought are from Halfords and as you said, are 5w, replacing the original Osram 4w bulbs.
    Do you know if this misallignment would throw out the rest of the bulbs on that same cluster? If they were on some sort of relay system i guess it could?
    Chris
  5. Re: Passat brake light bulb replacement
    Jun 2006
    3
    I don't know, it was a long time since I did the bulbs, but I remember one in there already being wrong, and the ones I had as spares in a drawer were like the wrong one, so I had to go to the shops and get more. I think the pins on the sides were in the wrong place (like higher up the side by a mm or two) or some such problem. The wrong one already in there was hard to get out. Sorry I can't be more precise.
  6. Re: Passat brake light bulb replacement
    Aug 2006
    0
    Hi Feegs
    I don't know whether your 02 is the same as my 04 Passat but since my last post I've found out that that the indicator bulb is not attached to the main plate where all the other bulbs are. You need to twist the grey lug to remove the indicator bulb first. The main light plate will then come out much easier.
    To replace, fit the light plate first then the indicator bulb. Be careful as there are a couple of electrical contacts on the indicator bulb attachment which need to click into the main bulb plate as you twist.
    Who knows why this is such a complicated set up but once you know how it works it's much simpler tp replace bulbs.
  7. Re: Passat brake light bulb replacement
    Aug 2006
    0
    By the way, I got my rear brake light from VW in Bury. I was amazed that it was only 1.50! No box or anything but what a bargain.
  8. Re: Passat brake light bulb replacement
    May 2007
    0
    hi nobby & snapdragon,
    thank you both for the info. Nobby, i didnt actually have a Haynes manual at hand when i performed the bulb replacement....I fear that i maybe let anger get the better of me and maybe forced the indicator bulb stalk unecessarily! I'll remove the whole lot as you advised, take another look at the bulb connections as snapdragon suggested and see what happens.....if still nowt then i guess it's VW dealership here i come ;o)
    cheers guys
    feegs
    (by the way Haynes manual is now in the post, to prevent any future ****ups!!!)
  1. Replacement Stop & Tail Light Bulb
    By Black Cab in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-05-2011, 10:40 AM
  2. a4 brake light bulb
    By mike d in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-02-2008, 07:00 PM
  3. RS6 Brake Light Bulb Replacement
    By rief944t in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-07-2007, 08:37 AM
  4. brake light bulb!!!!
    By jjt5 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-05-2007, 11:09 PM
  5. Instrument light bulb replacement!
    By theenglishman in forum 80 - 90
    Last Post: 21-12-2006, 08:56 AM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
VW Audi Forum is an AUTHORISED retailer for the Surf City Garage range of car care products
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
