Thread: Polo 1.8 GTI - EPC light/Loss of power - With Code
  1. Polo 1.8 GTI - EPC light/Loss of power - With Code
    Jul 2012
    Cardiff, Wales
    I have searched around these forums and found many people reporting the EPC light but none showing any similar symptoms or solutions, hope someone can help...
    My issue is that when revving anything above around 2000RPM the EPC light comes on and the I appear to lose power when moving (the revs stop increasing and the Car 'jerks') - the engine never stalls and when at a standstill the engine revs perfectly normally but the EPC light still comes on.
    I friend has plugged it into his generic diagnostics kit and it reporting fault: P0321 - Generic - VOLKSWAGEN - Ignition Engine Speed Input Circuit Range/Performance
    Based on my limited knowledge and research the EPC light suggests this is something to do with the electronic pedal control switches - however the above fault code suggest others things.
    I don't want to start replacing nonreturnable sensors without understanding some more - is this a common fault for this Car? If it an EPC sensors would it likely to be the pedal end or the 'engine' end?
    Thanks in advance
    Mike
  2. Re: Polo 1.8 GTI - EPC light/Loss of power - With Code
    UK Ex-pat now in Australia
    It sounds like you have a sensor down - it is giving you upto 2000rpm which is limp home to get you to a garage. You could have a crank speed sensor fault, a camshaft sensor fault if fitted, a throttle body fault or a pedal fault etc.
    there is information missing from one of these and therefore the ecu cannot safely determine what to do. You would need to get a diagnostic session carried out to determine which information is missing and what needs to be replaced.
    Had MKV GTI, Now Ford Falcon
  3. Re: Polo 1.8 GTI - EPC light/Loss of power - With Code
    Jul 2012
    Cardiff, Wales
    Thanks for the feedback, the secondary test using the move advanced testing equipment did not provide any further information. I therefore renewed the crank sensor (28GBP), cleared the fault codes and all appears to perfect so far
    Thanks again
    Mike
  4. Re: Polo 1.8 GTI - EPC light/Loss of power - With Code
    1840 Post(s)
    16705 (P0321)- Engine Speed Sensor (G28): Implausible Signal
    Possible Symptoms
    • Engine shuts off
    • Engine doesn't start
    • Speedometer inoperative
    • Glow Plug Indicator Lamp (K29) flashes
    Possible Causes
    • Engine Speed Sensor (G28) loose
    • Engine Speed Sensor (G28) faulty
    Possible Solutions
    • Check Engine Speed Sensor (G28)
    Special Notes
    • The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position and correlates with the Camshaft Position Sensor Bank 1 (G40) and Camshaft Position Sensor Bank 2 (G163).
      • When an engine will not start due to mechanical timing or spark/fuel related issues it is not uncommon to set G28/G40/G163 fault codes. The basics should be checked if this code returns after extended craning and a no-start with a new sensor installed.
  1. Polo 1.4 16V - EPC light, oil and service light issues
    By Trinster in forum Polo - Derby - Lupo - Fox
    Last Post: 19-08-2011, 08:57 PM
  2. Polo GTI EPC/Power Loss Issue - help?
    By Tobias in forum Polo - Derby - Lupo - Fox
    Last Post: 12-04-2010, 09:08 AM
  3. Epc light code 16524
    By bez101 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 26-01-2010, 10:39 PM
  4. help please epc light fault code 17961/cambelt
    By justin@justinwa in forum Golf MK4 - 1999 - 2004
    Last Post: 07-03-2009, 11:09 PM
  5. epc light , esp light , low power , high revs ..help...
    By b2online in forum Audi A3 - Archive Topics
    Last Post: 06-05-2008, 11:32 PM
