Thread: quantity adjuster code?? 17970 (n146) p1562
  1. quantity adjuster code?? 17970 (n146) p1562
    Nov 2008
    0
    i have a major issue that just popped up with my car the other day..
    i was driving home from work i called into tescos and when i got back and started the car it revved upto about 2000rpm on the inital start up and then the glow plug light on the dash kept flashing...i keep a code reader in my car so i pulled into a layby and plugged it in and got this code 17970 quantity adjuster (n146)upper limit reached1562 static - no indication on display.
    i took a look in the engine bay to see if i could anything was out of place,took the top cover of the engine so i could check everywhere up top and everything seemed normal...i actually got the code cleared after i put the engine cover on and got my socket set put away...so i drove home steady enough constantly looking down at the dash to see if the glow plug light started flashing again,it didnt..
    the next morning my wife took the car to work and when she came home she noticed revved up on start up and the light came on,she drove home and had to pull in of a slip road cause she said the car was revving up but the accelaration dropped..she stopped for about 10 mins and got the car going again and made her way home...
    do you think the injection pump is done?or would there be another issue that would cause this?i keep the car in good working order...always change fuel filters evrytime i do the oil and air filters when i service it..any suggestions would be appreciated
    thanks
    malcolm
  2. Re: quantity adjuster code?? 17970 (n146) p1562
    Jan 2009
    towcester northants
    145
    i presume its a pre pumpa diesel engine?
    if the quantity adjuster fault comes up the pump timing or cam timing could be out
    you need to read the measuring blocks of the diesel pump to check
    some of the early pumps use to break the wires to the pump
  3. Re: quantity adjuster code?? 17970 (n146) p1562
    Nov 2008
    0
    Quote Originally Posted by towcestervag View Post
    Yes its the bosch 110bph ahf block
    Do you need vag co. To do those readings?mine is just a handheld code reader
    Is there a way of working out if a wire has broke.what procedure would i use?
  4. Re: quantity adjuster code?? 17970 (n146) p1562
    Jan 2009
    towcester northants
    145
    Quote Originally Posted by mjrplan9 View Post
    you need a vcds or similar so you can read measuring blocks/live data
    visual check the wiring plug at main fuel pump loom and make sure the wires are not broken at connector
    if all ok then you need to check cam timing and then set up pump timing
    with engine running and at 80 degrees then set the machine into basic setting mode
    in the live data you need to read block 2 which is fuel temp and block 9 which is dynamic timing
    depending on what pump it has it could be around 50-60 in block 9
    i hope this is of help
  1. Adjustment of injection quantity....
    By rob1976 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-04-2012, 12:05 PM
  2. Question aircon refrigerant quantity 1.6 beetle
    By jkh112 in forum Beetle 2000-
    Last Post: 04-05-2011, 09:56 PM
  3. Question Engine Oil Quantity
    By mick9879 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-11-2010, 06:19 PM
  4. injected quantity automatic transmission
    By PADDYPONCHERO in forum VCDS - Help Requests
    Last Post: 03-10-2009, 01:29 PM
  5. Please Help quantity adjuster
    By deezilbob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-12-2008, 06:56 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
VW Audi Forum is an AUTHORISED retailer for the Surf City Garage range of car care products
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
