Welcome to the VW AUDI Forum - VWAF.
Results 11 to 20 of 30
Thread: ECU Remapping
  1. #11
    May 2009
    Newcastle-under-Lyme Staffordshire
    225
    Re: ECU Remapping
    Quote Originally Posted by jcdub View Post
    Try shark performance, he gets great reviews
    I haven't seen Ben from Shark on here for a while, but I think he is a site sponsor. People who used him and reported back always seemed to be very pleased. He does an equivalent of V-Switch too, so you can switch maps or even install a map to disable the engine if you are leaving the car unattended for a while.
    MF.
    MY2012 A6 Saloon 2.0TDi S line - Ice Silver, Tech Pack, DAB, Storage Pack, Lighting Pack, Heated F+R Seats, 4 zone A/C, 75l Tank, 20" Rotors, Boot Liner, Umbrella Brackets. VCDS mods: Needle sweep, VIM, Beep on lock, Hidden Menu, Kerb lighting, Mirror Dip on Reverse.
    A6 figure salary, A6 pack, A6. One out of three is a start!
    Got an A6 TDi? Join the A6 TDi Club! Got an A6 Le Mans? Join the A6 Le Mans Club!
  2. Thanks gupsterg thanked for this post
  3. The Following User Says Thank You to MFGF For This Useful Post:
    gupsterg (16-05-2012)
  4. #12
    Mar 2008
    Cliffe, Rochester
    3
    Re: ECU Remapping
    I sell the alientech powergate also just like all the others. The alientech powergate is simply rebranded with each tuners logo on it and so each tuner can supply their own maps for the units. Brilliant tool and I have sold many of these over the years, they also double as a BASIC diagnostic scanner for the particular ecu that it is set up for. I actually have a master version as one of my tools and it never lets me down.
  5. Thanks gupsterg thanked for this post
  6. The Following User Says Thank You to Aptuning For This Useful Post:
    gupsterg (17-05-2012)
  7. #13
    Nov 2009
    N.Ireland
    864
    My 2009 2.0 tdi is mapped without any issues. I doesn't have the tri lock ecu. Makes a nice difference plus better economy. Don't touch the blue fin. I tried it and the gains are poor and it didn't feel much different. Go with a custom map if possible. Try shark performance, he gets great reviews
    Got that confused with something else!
    What I meant was the 2011 cars need the ecu removed .. Doh!
  8. #14
    Aug 2011
    Surrey
    6
    Re: ECU Remapping
    Well I certainly think a remap is the first thing in order to get done after the MOT on Saturday... then maybe a think about whats next... an Stainless steel exhaust might be an option but at the moment Im not convinced that on a 2.0lt tdi its gonna sound impressive, sporty or grunty ....maybe on a 2.7lt or a 3.0lt
    But then on the other hand getting a stainless steel exhaust, compared to having a replacement exhaust works out cheaper in the long run...plus I can always sell the current one on ebay once Ive had it done
    Then I also have to consider the service is due in 90 or so days and I still want a VAG COM....and no I havent got a money tree... just wanna spend some money on me for a change instead of everyone else in this bloody house hold...wife and kids and all...
  9. #15
    Mar 2008
    Cliffe, Rochester
    3
    Re: ECU Remapping
    Quote Originally Posted by swampey View Post
    I know the feeling matey, you work all the hours and never get to spend any of the money you earn before family and bills come along!
    Did you get my PM? You have my number if I can be of any further help.
  10. Thanks swampey thanked for this post
  11. The Following User Says Thank You to Aptuning For This Useful Post:
    swampey (17-05-2012)
  12. #16
    Aug 2011
    Surrey
    6
    Re: ECU Remapping
    Yes I did and Im still exploring some tuning options at the moment
  13. #17
    Sep 2011
    Lurking over a keyboard!
    74
    Re: ECU Remapping
    Quote Originally Posted by Aptuning View Post
    Hi, just doing ground work at mo is mileage on engine a factor you look at for remap? mine@76K 3.0TDi PS225
    Does a little remap effect service interval? once a year oil change at mo
    Would reliability/problems on car be exasperated by remap? like on PC if you overclock shorten life of component etc
    Do your remap receive updates?
    Thanks in advance
    If knowledge is power ... then share knowledge to empower others ...
  14. #18
    May 2009
    225
    I enquired about one of the plug-in remapping devices a while ago, and I was told that it couldn't be used on my 2009 car as the ECU encryption hadn't been cracked. I was told a standard remap was possible, utilising a different area in memory than the standard map. I guess things have moved on since then, though - it was probably 18 months ago.
    Cheers!
    MF.
    Sent from my iPad using Tapatalk HD
  15. #19
    Aug 2011
    Surrey
    6
    Re: ECU Remapping
    Wonder what the cost of one of them alientech powergate are compared to Bluefin and V Switch Box and is it as good
    Humm had a look at shark, Just same as the V Switch box......and costs £50 more and Ive seen V Switch box is on a special deal at the moment
  16. #20
    Mar 2008
    Cliffe, Rochester
    3
    Re: ECU Remapping
    Mileage can be a factor, if for example it's over 100K then I would not like to put on a full power map unless the customer specifically asks for it.
    As for service intervals, a yearly service is fine denpending on the mileage you do.
    generally speaking a remap is not going to exasperate componants anymore than standard software as it is all done within safety limits of the engine. I currently run a saab 9-3 2.0T aero 210bhp which i have mapped to approx 285bhp. As I have mapped it to this point the extra torque which is 90Nm more than standard, it has nearly done the clutch in but then my car does have 112K at present. But other than this the car is running spot on with no other problems. So you see their really is not anything to worry about with the car remapped.
    Quote Originally Posted by gupsterg View Post
    Thanks in advance
  17. Thanks gupsterg thanked for this post
  18. The Following User Says Thank You to Aptuning For This Useful Post:
  1. Mobile ECU Remapping - 15% off for Forum Members
    By peakperformance in forum The Commercial Range
    Last Post: 14-06-2011, 10:59 AM
  2. ECU remapping company Reviews/Recommendations
    By smohamm527 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-01-2011, 12:29 PM
  3. ECU Remapping (1.9TDI)
    By Egg Roll in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-12-2009, 06:37 AM
  4. Question ECU Remapping - Need advice & Help!!
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 29-06-2009, 02:48 PM
  5. ECU remapping
    By shuggie1977 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-03-2008, 07:43 AM
Back to top
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Copyright: VW Audi Forum is an AUTHORISED DEALER for the Surf City Garage range of car care products. All Surf City Garage images are "Copyright" of Surf City Garage
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
- www.vwaudiforum.co.uk - www.vwaf.co.uk - www.vwaf.co.uk - www.vwaudiforum.co.uk -
/p
