Thread: Tailgate hinge bolt snapped
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Tailgate hinge bolt snapped
    Aardvark4Design Guest
    One of the bolts holding the plate to the hinges on my auto-open estate tailgate has sheared off, so it looks like a tialgate off completly job! Is this a difficult job? Has anyone heard of this happening before as there appears to be only one small bolt either side.
    1 1 0
  2. Re: Tailgate hinge bolt snapped
    May 2012
    U.K.
    You know what, mine did exactly the same only a few weeks ago. It's a 2006 model and the bolt on the right hand side has sheared. It's the one that connects the black bit that looks like part of the opening / closing mechanism to the main hinge. Opening seems fine as it effectively pushes it but, on closing, you can see that this bit isn't doing anything and all the load is on the other side.
    Was trying to figure out if it was easy just to undo the bolts holding it altogether on the affected side, drill out the sheared bolt and replace, but haven't got around to doing anything as yet. Guess the tailgate would have to be supported somehow if this was the course of action? Also, wonder if it could be welded in situ?
    Notwithstanding the car is out of warranty, I'm guessing a dealer would class it as 'wear and tear' so would have no comeback? It's obviously a part under a lot of stress which has eventually caused it to shear.
    1 1 0
  3. Re: Tailgate hinge bolt snapped
    Dealer quoted me 3-4 hours labour + parts (89p for 2 bolts!) but I managed it in 25mins. Feel free to PM me and I'll give you my number and you can give me a call and I will talk you through it.
    2 1 0
  4. Re: Tailgate hinge bolt snapped
    May 2012
    U.K.
    You'll have to PM me if you don't mind as I'm getting the message: "Note: Until your post count is 10 you will be able to send PMs to Staff only."
    Doh!
  5. Re: Tailgate hinge bolt snapped
    May 2013
    Canada
    This just happened to our Passat wagon and I slightly baffled on how to remove the remaining portion of the bolts (both sides are snapped). The access is VERY small so drilling/tapping seems out. I'm thinking of either lowering the door slightly and trying to angled the screw portion so I can manage to back it out (or go forward) OR remove the damn hinge completely and support the tailgate and remove the screw.
  6. Re: Tailgate hinge bolt snapped
    Quote Originally Posted by mywifespassat View Post
    Feel free to give me a ring and I will talk you through it.
    07843 913 723
  7. Re: Tailgate hinge bolt snapped
    May 2013
    Canada
    Quote Originally Posted by Aardvark4Design View Post
    Firstly, A4D is a great guy to talk to, and he was very gracious in scheduling our overseas chat
    So the idea is to remove the hinge to get access to the portion of the snapped bolt that's still in the threads since the access to this portion is pretty much impossible as installed. The top portion of the hinge that connects to the actual tailgate has 2 screws with a hex head (will post size when I do it), and the lower portion that connects to the car has 2 ROUND-headed bolts that I initially thought might be rivets but "Aardvark4Design" indicated that on the reverse side there are nuts. How to get to the reverse side? Well if I understood correctly, there's some plastic trim near the dome light below the area where these nuts would be accessible. It looks like it could be removed but I played with it a bit and I didn't find a way to do it without breaking it. Also, it's not clear how those lower bolts can be removed without having those ROUND heads turning too. A4D? I'll also take some pics because I feel this is bound to happen to others since heads snapping is an odd failure unless they're safety bolts, which they don't seem to be. In my case BOTH bolts are snapped, probably at different times as A4D pointed-out.
    PS: Sorry I couldn't PM you, the site won't let newbies send PMs.
  8. Re: Tailgate hinge bolt snapped
    This is the trim to remove, you may have to remove the side trim also. The bolts between the hinge and the car are retained/fixed to the hinge so will not spin when you undo the nuts from the other end.
    2 0 0
  9. Re: Tailgate hinge bolt snapped
    Jul 2013
    Finland
    Do i just pull the trim in order to remove it or is there some kind of special trick I need to know about?
    Thanks in advance.
  10. Re: Tailgate hinge bolt snapped
    Quote Originally Posted by celindho View Post
    Thanks in advance.
    You just need to gently pull it down.
  1. Question Audi 80 Avant Tailgate hinge wiring ???
    By Timk in forum 80 - 90
    Last Post: 07-05-2012, 10:07 AM
  2. Rear Washer Pipework - tailgate hinge
    By NickPicks in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-02-2012, 05:16 PM
  3. arrow in tailgate hinge
    By asrpaint in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-01-2011, 04:17 PM
  4. Snapped glovebox hinge
    By JON4C in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-03-2010, 10:58 PM
  5. Drop link bolt snapped in roll bar
    By rob160 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-06-2008, 01:16 AM
