Thread: 2007 1.4tsi boost problems ***HELP***
  1. 2007 1.4tsi boost problems ***HELP***
    Aug 2008
    1
    for a number of months now i have been trying to fix a 2007 golf 1.4tsi engine code blg, the problem is with the switch over from supercharger to turbo. we have tried a number of things to sort the problem but so far no joy.
    to start with the fault codes we had were
    Address 01: Engine Labels: 03C-906-032-BLG.lbl
    Control Module Part Number: 03C 906 032 A HW: 03C 906 032
    Component and/or Version: MED17.5.1 9971
    Software Coding: 0000072
    Work Shop Code: WSC 00442 210 91419
    VCID: 1B3E003BA33E
    2 Faults Found:
    008801 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    P2261 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 58824 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:04:25
    Freeze Frame:
    RPM: 2590 /min
    Load: 26.7 %
    Speed: 61.0 km/h
    Temperature: 85.0C
    Temperature: 16.0C
    Absolute Pres.: 970.0 mbar
    Voltage: 13.970 V
    004261 - Position Sensor for Intake Air Regulating Flap: Signal too High
    P10A5 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 58824 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:04:21
    Freeze Frame:
    RPM: 2737 /min
    Load: 90.6 %
    Speed: 53.0 km/h
    Temperature: 85.0C
    Temperature: 18.0C
    Voltage: 13.589 V
    the boost pressure control was cleared by replacing valve on side of turbo, we was left then with the position sensor for intake reg flap. we tried pcv on top of engine, both intake reg flaps but still no joy. then as the car was on its way back to try the clutch for supercharger it decided to blow a piston (cylinder 4).
    to repair that we fitted a new piston, rings on all 4 cylinders, full set of shells on crank and con rods (not looking worn but pitted), timing chain, oil pick up pipe, gaskets and seals. now that the engine has been rebuilt we could continue to try and find the boost problem, so the supercharger clutch was fitted, and once again still boost problems. the position sensor flap fault has now gone but the boost prblem has not.
    whilst out on another test drive a dtc was stored (misfire cylinder 4), we decided that we would replace injector number 4 as this could of helped in the destruction of the piston. now replaced we scaned before another test drive we have found a different fault
    Part No SW: 03C 906 032 A HW: 03C 906 032
    Component: MED17.5.1 9971
    Revision: 96H06--- Serial number: VWZ7Z0F8011590
    Coding: 0000072
    Shop #: WSC 00442 210 91419
    VCID: 1B3E003BDABEE11
    1 Fault Found:
    008196 - Intake Manifold Flap; Bank 1
    P2004 - 000 - Stuck Open
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 59890 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 09:26:33
    Freeze Frame:
    RPM: 821 /min
    Load: 12.9 %
    Speed: 0.0 km/h
    Temperature: 51.0C
    Temperature: 8.0C
    Absolute Pres.: 980.0 mbar
    Voltage: 14.224 V
    Readiness: 0110 0101
    stripped back down the flaps seem ok and move freely, the vac pipes seem ok as does the actuator. so we presumed it must be the potentiometer and fitted a new one, but still we have the intake manifold flap stuck open fault. (no visable fault as we can see the actuator moving)
    we decided to take it out on a drive to see if it would clear itself, but still no joy.
    so after all the problems and repairs we still have the boost problem but non of the original dtc's
    the boost problem will only occur after driving for about 10 or 15 minutes. if the car is left idling for any length of time (even an hour) it will still take about 10 or 15 minutes of driving before the fault happens. the fault has been the same all the way through the repairs and changes of parts, the only thing that has changed is the fault codes.
    can anyone please help, as i am runing out of options with this one now.
  2. Re: 2007 1.4tsi boost problems ***HELP***
    Mar 2013
    wassenaar
    0
    I have the same problem with my 2007 VW golf 1.4 tsi bns, what was for you the answer to the problem. Because we are also out of options. We have also changed different "ventil" parts. also the the sensor has no malfunction we checked it diffrent time`s. No leaking in vacuum system. Changed the bougies, etc. Still the same problem.
  1. Please Help 2007 T5, handful of random problems...
    By Davidkent in forum The Commercial Range
    Last Post: 21-01-2012, 12:26 AM
  2. boost problems
    By granttd73 in forum Leon
    Last Post: 14-03-2011, 09:03 AM
  3. Braking problems with my 2007 a4 b7!!!
    By madskillzuk in forum New Member Introductions - Sponsored by BVR Automotive
    Last Post: 14-05-2010, 07:32 PM
  4. boost problems
    By jpresto in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-10-2009, 07:54 PM
  5. Please Help Boost Problems
    By Dre25 in forum Bora - 1998 - 2005
    Last Post: 26-10-2008, 10:42 AM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
