Thread: A6 C7 VCDS Tricks
Page 1 of 90 1231151 ... LastLast
Results 1 to 10 of 897
  1. A6 C7 VCDS Tricks
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Armed with my list of tricks from my C6 and other people's A4s and A5s I have experimented with, I decided to see what I could find and enable on my new A6 C7. I had some success, but not so much in other areas...
    Pre-facelift Cars - 11 - 64 plate
    1. Enabling Gauge Test/Needle Sweep
    This will sweep the needles of the speedo and rev counter through their full range automatically when you start the engine.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    [Long Coding Helper]
    Click on byte 1 and you'll see the selectable option: "Gauge Test/Needle Sweep active"
    Check this option
    [Do It!]
    This produced expected results
    2. Enabling Lap Timer
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Click on byte 1 and you'll see the selectable option: "Lap Timer active"
    Check this option
    [Do It!]
    This made no apparent difference to the DIS options between the clocks. Maybe I just have to find the right sequence to get to it?
    Edit 07-09-12. Although this doesn't work on my car, it does on some. The Lap Timer option appears in the DIS menu on page 2 when you press the * button on the steering wheel and scroll down. You may be luckier than me and find it works on your car?
    3. Kerb lighting
    Illuminating the kerb when turning hard left or right at low speeds with dipped beam on, by turning on the all-weather light on the relevant side of the car.
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    Click on byte 4 and enable bit 0
    [Do It!]
    I have now (finally) tested this works as expected. I needed a dark night and a quiet corner
    4. Beep on lock
    Chirp the alarm siren briefly when the alarm activates (ie all doors are closed and the car is locked)
    [Select]
    [46-Central Conv.]
    [Coding - 07]
    Click on byte 1 and in bit 2 you'll see the selectable option: "Anti-Theft-System: Horn Confirmation active"
    Check this option
    [Do It!]
    5. Hidden menu
    Enable access to the green engineering menu in the MMI
    [Select]
    [5F - Information Electr.]
    [Adaptation - 10]
    Select Channel 6 and Read
    change the value from 0 to 1 then Test then Save
    Reboot the MMI (Press MENU, central MMI knob and top right softkey)
    To get to the Hidden Menu, press and hold the CAR and MENU buttons for a few seconds. You may have to have a few attempts - if you don't press them at the exact same moment either CAR or MENU activates. You know if you have done it right because the red LEDs in the buttons do not illuminate.
    WARNING!!!! BE CAREFUL!!! Do not mess with settings in the Hidden Menu unless you know what you are doing. On earlier MMI versions, people managed to activate the bootloader menu and fried their MMI. Use at your own risk. If in doubt, leave well alone!
    This worked as expected.
    6. Battery Meter.
    Enter the Hidden Menu as in step 5 above.
    Select Car
    Select Carextdevicelist
    Check "Battery"
    Return
    Select Carmenuoperation
    Set "Battery" from 0 to 5
    Return
    Press CAR to exit the hidden menu
    Reboot the MMI
    Despite doing this, I could not find the battery meter displayed anywhere. I am a muppet though - it may be lurking in a menu I haven't found yet
    7. VIM
    Video In Motion - prevent the car from suppressing DVD playback once the speed of the car rises above 5mph
    I used the same technique as in my C6 with MMI 3G. These are the steps I followed:
    [Select]
    [5F-Information Electr.]
    [Advanced ID - 1A]
    Make a note of the Serial Number
    Go to Enable VIM TV-playback using VCDS/VAG-COM in your Audi MMI | trick77.com
    Follow the link for MMI 3G
    Enter your serial number into the input field
    Make a note of the personal login code and the alternative login code it returns
    [Security Access - 16]
    Enter your personal login code.
    [Do it!]
    If you receive a "code not valid" message try the alternative code. If neither code works it's likely that your control module doesn't support VIM adaptation.
    [Adaptation - 10]
    Select channel 48
    Press read
    Set the value from 0 to 255
    Press test
    Press save
    Press "Done, Go Back"
    Close VCDS and reboot your MMI as detailed in step 5 above
    This works as expected.
    8. Passenger door mirror dip on selecting reverse.
    When reverse gear is selected, the passenger door mirror dips to show the kerb if the mirror control knob is set to the passenger door mirror position. When driving forwards and exceeding 5mph or when switching off the car, the passenger mirror returns to its original position. If the position of the mirror is changed when dipped, this change is remembered the next time the mirror dips.
    [Select]
    [52 - Door Elect, Pass]
    [Coding - 07]
    Click on Byte 4 (5th one along from the left)
    Set Bit 2 to "on"
    [Do It!]
    Full details of this mod are lower down in the thread - it is a little disconcerting at the moment because VCDS has no information for the module and displays a warning when selecting Long Coding Helper. This works as expected
    9. Disabling seatbelt reminder chimes.
    Turn off the annoying "Bing bong" when you move the car on the driveway without your seatbelt fastened.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Click on byte 0 and in bit 4 you'll see the selectable option: "Seat Belt Warning inactive"
    Check this option
    [Do It!]
    Thanks to Mr Fish for finding and posting this up.
    10. Disabling engine stop when opening driver's door.
    Recode the Central Convenience module to STOP the engine from turning off when you get out, having moved the car.
    [Select]
    [46 - Central Conv.]
    [Coding - 07]
    Click on the red byte (below) and in the binary code you will see: 00000111
    Change it to: 00001111
    ie. with 1111 at the end not 111
    Tab into the next bit box and you will see the code change to 0F (013F062220B9000083200904200104070000000000000000000000000000 to 013B062220B90000832009042001040F0000000000000000000000000000)
    [close the long code helper]
    [Do It!]
    11. Enabling the default distance setting in the MMI for Adaptive Cruise Control
    Adding the option to modify the default distance for ACC (values 1 to 4) via the MMI
    [Select]
    [13 - Auto Distance Regulation]
    [Adaptation - 10]
    Select channel 07
    Press read
    Set the value from 0 to 1
    Press test
    Press save
    In the MMI you should now be able to go to Car > Driver Assistance > Adaptive Cruise and see a new option there to set the adaptive cruise distance.
    Thanks to M1tchy for finding and posting this up.
    12. Modifying the High Beam Assist speed threshold
    Changing the threshold speed at which High Beam Assist activates
    [Select]
    [20 - High Beam Assist]
    [Adaptation - 10]
    From the drop-down menu, select "High Beam Speed Threshold"
    In the third entry box down on the left, enter the speed to set the threshold to in KM/h (eg 40)
    Press save
    Thanks to JK88 for finding this and to M1tchy for posting this up.
    13. Enabling the Daytime Running Lights on/off setting in the MMI
    Adding the option to turn off / turn on the DRLs via the MMI
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    Click on byte 3 and enable bit 0 (Daytime running lights adjustable via MMI)
    [Do It!]
    Thanks to diecastsink for finding and posting this up.
    14. Enabling tourist mode setting for headlights in the MMI
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    Click on byte 4 and enable bit 6
    [Do It!]
    15. Enable auto handbrake when shift into P
    [Select]
    [53 - Parking Brake]
    Code displayed to me was - 78713
    [Adaption - 10]
    [Select]
    "Shift P to EPB"
    Set to Activated
    [Do It!]
    Thanks to A6_Chris for finding and posting this up.
    16. Close electric boot lid from key
    [Select]
    [46 - Cent Conv]
    [Coding - 07]
    Click on byte 2, bit 2
    Tick Comfort operation: Remote control active
    [Do It!]
    [Select]
    [4D - Trunk Elec]
    Input 12345
    [Adaption - 10]
    Activation using rear lid opening button in remote key - Touch function for closing
    Change to ACTIVE
    [Do It!]
    Thanks to M1tchy for finding this and to A6_Chris for posting this up.
    16b. Close electric bootlid from key and driver's door switch - Facelift models
    [Select]
    [46 - Cent Conv]
    [Coding - 07]
    Byte 2, bit 2 "Comfort operation: Remote control active" should be checked, so no need to change it, just confirm that it's set.
    No Change, Original Coding: Bit 2 checked
    [Select]
    [6D - Trunk Elec]
    Input 12345
    [Adaption - 10]
    There are 8 options for "Activation using rear lid. . .". Change the two "number 4" settings to active.
    Original Coding:
    (1)-Activation using rear lid opening button in remote key - Touch function for opening: not active
    (2)-Activation using rear lid opening button in remote key - Tap function for opening: active
    (3)-Activation using rear lid opening button in remote key - Touch function for closing: active
    (4)-Activation using rear lid opening button in remote key - Tap function for closing: not active
    (1)-Activation using rear lid remote unlocking switch - Touch function for opening: not active
    (2)-Activation using rear lid remote unlocking switch - Tap function for opening: active
    (3)-Activation using rear lid remote unlocking switch - Touch function for closing: active
    (4)-Activation using rear lid remote unlocking switch - Tap function for closing: not active
    New Coding:
    (4)-Activation using rear lid opening button in remote key - Tap function for closing: active
    (4)-Activation using rear lid remote unlocking switch - Tap function for closing: active
    Changing the first "number 4" allows closing of the trunk lid with a quick press of the trunk button on the remote control.
    Changing the second "number 4" allows closing of the truck lid with a quick pull of the trunk switch (in the driver's side door)
    The trunk is still opened as before. It will beep when remote closing.
    Thanks to A6S for finding and posting this up.
    17. Enable double disarm chirp
    [Select]
    [Adaption - 10]
    Channel 63
    Add 4
    [Do It!]
    (Prompt shows options for other settings)
    Thanks to shaneypoopers for finding and posting this up.
    18. Disable DRL dim on turn signal
    [Select]
    [09 - Central Elec.]
    Code: 20113
    [Adaption - 10]
    Channel 3
    Set between 5 and 100
    [Do It!]
    (I found 50 to be a good setting)
    19. Parking brake release without seat belt on
    [Select]
    Code presented by program
    [Adaption - 10]
    Select from drop down menu
    Change parameter
    [Do It!]
    20. Tail lights on with front DRLs
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    Click on byte 2 and enable bit 7
    [Do It!]
    Thanks to Kaner for finding and posting this up.
    21. Enable ripping from CD to MMI HDD
    Select Main
    Select Diagnose
    Select Settings
    Select Import_Multimedia
    Check "Ripping"
    Return
    Reboot the MMI
    22. Enable "Make calls using" feature in cars before MY2013 that have been updated to MMI 0770
    Select Main
    Select Diagnose
    Select Settings
    Select tel_settings
    Check "NAD operation mode"
    Return
    Reboot the MMI
    After the reboot you will be prompted with the option to choose which device to use to make calls. Once you've selected which phone to use to make calls (mmi or mobile telephone) the system will advise a reboot is required which it will do itself.
    Thanks to ndiye for finding and posting this up.
    23. Adjust brightness of DRLs when headlights are on
    [Select]
    [09-Cent. Elect.]
    [Security Access - 16] (enter security code - 20113)
    [Adaptation - 10]
    Select Channel 03 and Read
    Change the value from 5 to 100
    Press Test then press Save
    24. Alter the switch-off speed of the Audi parking System
    [Select]
    [10 - Park/Steer Assist]
    [Adaptation - 10]
    Select Channel 23 and Read
    Change the value from 10 to 20 (Max speed in Km/h - 20 is the highest you can set it to)
    Thanks to DB22 for finding and posting this up.
    25. Disable/memorize/invert Start & Stop
    [Select]
    [09-Cent. Elect.]
    [Adaptation - 10]
    Select Channel 34 and Read
    if you subtract 4 from the original value --> Start&Stop always disabled
    if you add 32 to the original value --> memorize last status (the Start & Stop status at engine startup will be the one at last engine shutdown)
    if you add 64 to the original value --> Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled.
    26. Activation of footwell lighting for vehicles without Lighting Pack / Ambient Lighting
    This allows you to use the MMI to set the footwell lighting level while driving. Tested on cars with MMI 3G+ (Tech pack).
    [Select]
    [09-Cent. Elect]
    [Coding - 07]
    Click on byte 16 and enable bit 6
    [Do It!]
    Select Car
    Select Cardevicelist
    Check "Interior Light"
    Return
    Set "Interior Light" from 0 to 5
    Return
    Reboot the MMI
    Thanks to Hellodave for finding this.
    27. Changing the brightness range for the dashboard cluster
    This allows you to use the dimmer to completely turn off illumination of gauges and needles, increasing the available range of brightness options from the factory settings
    [Select]
    [17 - Instruments]
    Enter the code displayed by VCDS
    [Adaptation - 10]
    For each of the following channels, press Read
    set the value to 0 (zero)
    Press test
    Press save
    - dimming_characteristic_curve_adjustment_clock_dial _night-Y2 (this controls the illumination of the scales)
    - dimming_characteristic_curve_adjustment_gauage-Y2 (needles)
    - dimming_characteristic_curve_adjustment_extra_fiel d-Y2 (temp and fuel)
    - dimming_characteristic_curve_adjustment_middle_dis play_main_field-Y2 (DIS)
    Thanks to RobertJB for finding and posting this up
    Facelift Cars - '15 plate onwards
    Thanks to MichaelHein for researching the pre-facelift mods on his facelift car and whittling them down to the below list relevant to facelift models.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Check this option
    [Do It!]
    This adds an extra selectable screen in the DIS that displays lap timers, turbo boost and oil temperature. For cars with HUD it also shows a different HUD.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Check this option
    [Do It!]
    3. Kerb lighting
    Illuminating the kerb when turning hard left or right at low speeds with dipped beam on, by turning on the all-weather light on the relevant side of the car. This also works with Matrix LED lights.
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    [Do It!]
    4. Beep on lock
    [Select]
    [46-Central Conv.]
    [Coding - 07]
    Check this option
    [Do It!]
    5. Passenger door mirror dip on selecting reverse.
    When reverse gear is selected, the passenger door mirror dips to show the kerb if the mirror control knob is set to the passenger door mirror position. When driving forwards and exceeding 5mph or when switching off the car, the passenger mirror returns to its original position. If the position of the mirror is changed when dipped, this change is remembered the next time the mirror dips. This is enabled as standard on cars with electric memory seats but can be enabled using VCDS on cars that don't.
    [Select]
    [Coding - 07]
    Set Bit 2 to "on"
    [Do It!]
    Note - it is a little disconcerting when selecting Long Code Helper for Module 52 at the moment because VCDS has no information for the module and displays a warning. Ignore the warning and proceed as normal and you can code this mod successfully.
    6. Disabling seatbelt reminder chimes.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Check this option
    [Do It!]
    7. Disabling engine stop when opening driver's door.
    [Select]
    [Coding - 07]
    Tab into the next bit box and you will see the code change to 0F (013F062220B90000832009042001040700000000000000000 00000000000 to 013B062220B90000832009042001040F000000000000000000 0000000000)
    [Do It!]
    This needs to be verified as working on facelift cars. Not tested.
    8. Enabling the default distance setting in the MMI for Adaptive Cruise Control.
    [Select]
    [Adaptation - 10]
    Select channel 07
    Press read
    Press test
    Press save
    Close VCDS and reboot your MMI (Press MENU, central MMI knob and top right softkey simultaneously)
    9. Modifying the High Beam Assist speed threshold.
    [Select]
    [Adaptation - 10]
    Press save
    10. Close electric bootlid from key and driver's door switch.
    [Select]
    [46 - Cent Conv]
    [Coding - 07]
    [Select]
    [6D - Trunk Elec]
    Input 12345
    [Adaption - 10]
    Original Coding:
    New Coding:
    11. Enable double disarm chirp.
    [Select]
    [Adaption - 10]
    Channel 63
    Add 4
    [Do It!]
    Good luck if you try these changes yourself! If you know of any other tricks, please add them to the thread.
    MF.
    Last edited by MFGF; 20-04-2017 at 08:56 AM. Reason: Adding Dashboard Brightness modification
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
    16 8 0
  2. Re: A6 C7 VCDS Tricks
    Mar 2012
    Berkshire
    Very keen to follow this thread and see what else is posted.
    Slight tangent, but do you know if the VCDS software is available for OSX?
    Nov 2009
    46 Post(s)
    Quote Originally Posted by 5678 View Post
    I believe you can use Bootcamp or Paralells to create a Windows VM and then run vcds off that.
  4. Re: A6 C7 VCDS Tricks
    Mar 2012
    Berkshire
    Thanks Chris. Thought this may be the case.
    May 2009
    69 Post(s)
    Yep - that is the way to go. VCDS is not supported natively on a Mac. See FAQ 1.8 on the Ross Tech support site, here:
    http://www.ross-tech.com/vag-com/faq_1.html
    Cheers!
    MF.
    Snet form my fumblefingers
    iPhon 5 usig Tapatalk
  6. Re: A6 C7 VCDS Tricks
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I tried the kerb lighting but no success. I assume that the lighting switch should be set at automatic.
    3. Kerb lighting
    [Select]
    [09-Cent. Elect.]
    [Do It!]
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
    May 2009
    69 Post(s)
    Quote Originally Posted by shabazmo View Post
    3. Kerb lighting
    [Select]
    [09-Cent. Elect.]
    [Do It!]
    I haven't driven in the dark to be able to test it. Mine may well not work either. I will report back when I get the opportunity to test...
    MF.
    Sent from my iPad using Tapatalk HD
    May 2009
    69 Post(s)
    3. Kerb lighting
    [Select]
    [09-Cent. Elect.]
    [Do It!]
    I finally tried this tonight. With the switch on Auto, I saw the lighting pattern change as I turned sharp right before reversing into my drive. I kept my eye on the extra pool of light as I straightened the wheel, and saw it go again - it faded down rather than just cutting off suddenly. My car does not have AFS headlights, so it can only have been the all-weather light fading up and down for the sharp cornering manoeuvre. It only operates at low speeds I think.
    Cheers!
    MF.
  9. Re: A6 C7 VCDS Tricks
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I concur, it does work. When i first tried it, I don't know why it did not work, but it does now. Not sure about the extra benefit though, I have xenons, so did not notice much diference, but early days yet. will give an update later.
  10. Re: A6 C7 VCDS Tricks
    Feb 2012
    Epsom UK
    Is it possible to extend how long the ACC stays in Automatic Go?
    A6 SE Estate 3.0 TDi with no style but loads of gizmos
  1. Audi A4 B8 - VAG.com Tricks
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-03-2021, 05:34 PM
  2. mark 5 tips and tricks
    By m24man786 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2010, 09:58 AM
  3. Audi A6 Tricks ??????????????
    By slice636 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2009, 12:27 PM
  4. Question vag com tricks?
    By andymartin045 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2009, 07:43 PM
  5. tips and tricks for golf mk5's
    By Ben in forum Golf MK5 - 2004 - 2009
    Last Post: 17-08-2008, 09:25 PM
