Thread: A6 C7 VCDS Tricks
Page 37 of 90 FirstFirst ... 2735363738394787 ... LastLast
Results 361 to 370 of 897
  1. Re: A6 C7 VCDS Tricks
    The rSAP issue is an Apple one rather than an Audi one - and yes, it still exists. So you will need a separate SIM.
  2. Re: A6 C7 VCDS Tricks
    Apr 2009
    Surrey
    174 Post(s)
    Quote Originally Posted by CharlesElliott View Post
    Not just an Apple issue rSAP is no longer really being offered. Android phones offer require an app in order to allow them to support rSAP. Next generation cars will adopt Apple or Google car apps so the issue should go away. Still can't really understand why in this day and age car manufacturers can't work via wifi connection between the two devices for all the smart features since the phone stuff can all be handled by Bluetooth
  3. Re: A6 C7 VCDS Tricks
    Nov 2014
    Stafford
    8 Post(s)
    After one months of owndership of MY2014 A6 Allroad 3.0tdi 245ps I have purchased a new Ross Tech VCDS
    have enabled:-
    needle sweep
    chirp on lock
    fog lights on turning
    i have tried but as yet not got the keyfob to close the boot - but will give it anither go. Also need to do the VIM thing too.
    just wanted to say 'Hi' and thanks for the resource. Its my first Audi after the Volvo-dullness and so far its been a real pleasure
  4. Re: A6 C7 VCDS Tricks
    Has anyone had the battery meeting working on 3G+? I can't see any examples of it from searching the web.
  5. Re: A6 C7 VCDS Tricks
    Mar 2014
    Edinburgh
    235 Post(s)
    Hi guys
    need a bit of help from the vagcom gurus here.
    Tried activating the vim on my facelift and the security access code from the links don't work. Tried both codes now and they are both invalid.
    Also tried activating handbrake in park mode and that brought up the module has not been initialised do you want to load default values. So I thought I better not mess with the handbrake so left that too.
    Any help appreciated.
  6. Re: A6 C7 VCDS Tricks
    Nov 2009
    46 Post(s)
    Press yes to the default vaules. Maybe your 5F doesn't support VIM?
  7. Re: A6 C7 VCDS Tricks
    Mar 2014
    Edinburgh
    235 Post(s)
    Quote Originally Posted by Chris View Post
    Don't see why, it's exactly the same as my mates 2012 car.
  8. Re: A6 C7 VCDS Tricks
    Nov 2014
    Stafford
    8 Post(s)
    I managed to do the VIM today on MY14 Allroad and got the keyfob to close the boot too.
    also got the lap timer to work
    but implemented the battery status but could not find it in the menus so presume thats a step too far
  9. Re: A6 C7 VCDS Tricks
    Nov 2014
    Stafford
    8 Post(s)
    I tried and failed to get this working today on 3G+ MY14 Allroad
    reading trick77.com the number after the enable battery status option is the location of the battery status function in the menu struxture of CAR ?
  10. Re: A6 C7 VCDS Tricks
    Mar 2014
    Edinburgh
    235 Post(s)
    Hi Folks,
    for the VIM, what is channel 48 called? going down the list of channels there are numerous 48 with all sorts of descriptions.
    Another VCDS user has told me that it might not need the security code, either way it will be on the list of adaptation whether i need to use security code or not. if its not there, it just wasnt meant to be.
  1. Audi A4 B8 - VAG.com Tricks
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-03-2021, 05:34 PM
  2. mark 5 tips and tricks
    By m24man786 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2010, 09:58 AM
  3. Audi A6 Tricks ??????????????
    By slice636 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2009, 12:27 PM
  4. Question vag com tricks?
    By andymartin045 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2009, 07:43 PM
  5. tips and tricks for golf mk5's
    By Ben in forum Golf MK5 - 2004 - 2009
    Last Post: 17-08-2008, 09:25 PM
