Re: A6 C7 VCDS Tricks –
15-07-2014,12:35 PM
So thanks for the info Chris.
Splash and I tried to set up a few things on my allroad last night and here are the results - these are using the guidance off the first post.
- Lap timer / Oil temp / Boost works fine. Oil temp is the item of interest so pleased to be able to see that.- Battery meter, we tried to enable but I still cannot find it in the MMI- Passenger door mirror dip on reverse works as expected. As has been noted if you turn the adjuster knob away from the left mirror setting it does not dip (and if dipped returns to regular position)- Close boot with key does not seem to work
A6 allroad BiTdi (MY14, July 2013 - DAB & power tailgate). Glacier white, tech pack (HDD Nav, colour DIS, Parking Plus), sports seats, 4 zone climate, heated seats front and rear, ambient lighting, 75L fuel tank, adaptive Bi Xenon headlights
