Welcome to the VW AUDI Forum - VWAF.
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
  1. #1
    May 2009
    Newcastle-under-Lyme Staffordshire
    225
    A6 C7 VCDS Tricks
    Armed with my list of tricks from my C6 and other people's A4s and A5s I have experimented with, I decided to see what I could find and enable on my new A6 C7. I had some success, but not so much in other areas...
    1. Enabling Gauge Test/Needle Sweep
    This will sweep the needles of the speedo and rev counter through their full range automatically when you start the engine.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    [Long Coding Helper]
    Click on byte 1 and you'll see the selectable option: "Gauge Test/Needle Sweep active"
    Check this option
    [Do It!]
    This produced expected results
    2. Enabling Lap Timer
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Click on byte 1 and you'll see the selectable option: "Lap Timer active"
    Check this option
    [Do It!]
    This made no apparent difference to the DIS options between the clocks. Maybe I just have to find the right sequence to get to it?
    Edit 07-09-12. Although this doesn't work on my car, it does on some. The Lap Timer option appears in the DIS menu on page 2 when you press the * button on the steering wheel and scroll down. You may be luckier than me and find it works on your car?
    3. Kerb lighting
    Illuminating the kerb when turning hard left or right at low speeds with dipped beam on, by turning on the all-weather light on the relevant side of the car.
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    Click on byte 4 and enable bit 0
    [Do It!]
    I have now (finally) tested this works as expected. I needed a dark night and a quiet corner
    4. Beep on lock
    Chirp the alarm siren briefly when the alarm activates (ie all doors are closed and the car is locked)
    [Select]
    [46-Central Conv.]
    [Coding - 07]
    Click on byte 1 and in bit 2 you'll see the selectable option: "Anti-Theft-System: Horn Confirmation active"
    Check this option
    [Do It!]
    5. Hidden menu
    Enable access to the green engineering menu in the MMI
    [Select]
    [5F - Information Electr.]
    [Adaptation - 10]
    Select Channel 6 and Read
    change the value from 0 to 1 then Test then Save
    Reboot the MMI (Press MENU, central MMI knob and top right softkey)
    To get to the Hidden Menu, press and hold the CAR and MENU buttons for a few seconds. You may have to have a few attempts - if you don't press them at the exact same moment either CAR or MENU activates. You know if you have done it right because the red LEDs in the buttons do not illuminate.
    WARNING!!!! BE CAREFUL!!! Do not mess with settings in the Hidden Menu unless you know what you are doing. On earlier MMI versions, people managed to activate the bootloader menu and fried their MMI. Use at your own risk. If in doubt, leave well alone!
    This worked as expected.
    6. Battery Meter.
    Enter the Hidden Menu as in step 5 above.
    Select Car
    Select Carextdevicelist
    Check "Battery"
    Return
    Select Carmenuoperation
    Set "Battery" from 0 to 5
    Return
    Press CAR to exit the hidden menu
    Reboot the MMI
    Despite doing this, I could not find the battery meter displayed anywhere. I am a muppet though - it may be lurking in a menu I haven't found yet
    7. VIM
    Video In Motion - prevent the car from suppressing DVD playback once the speed of the car rises above 5mph
    I used the same technique as in my C6 with MMI 3G. These are the steps I followed:
    [Select]
    [5F-Information Electr.]
    [Advanced ID - 1A]
    Make a note of the Serial Number
    Go to Enable VIM TV-playback using VCDS/VAG-COM in your Audi MMI | trick77.com
    Follow the link for MMI 3G
    Enter your serial number into the input field
    Make a note of the personal login code and the alternative login code it returns
    [Security Access - 16]
    Enter your personal login code.
    [Do it!]
    If you receive a "code not valid" message try the alternative code. If neither code works it's likely that your control module doesn't support VIM adaptation.
    [Adaptation - 10]
    Select channel 48
    Press read
    Set the value from 0 to 255
    Press test
    Press save
    Press "Done, Go Back"
    Close VCDS and reboot your MMI as detailed in step 5 above
    This works as expected.
    8. Passenger door mirror dip on selecting reverse.
    When reverse gear is selected, the passenger door mirror dips to show the kerb if the mirror control knob is set to the passenger door mirror position. When driving forwards and exceeding 5mph or when switching off the car, the passenger mirror returns to its original position. If the position of the mirror is changed when dipped, this change is remembered the next time the mirror dips.
    [Select]
    [52 - Door Elect, Pass]
    [Coding - 07]
    Click on Byte 4 (5th one along from the left)
    Set Bit 2 to "on"
    [Do It!]
    Full details of this mod are lower down in the thread - it is a little disconcerting at the moment because VCDS has no information for the module and displays a warning when selecting Long Coding Helper. This works as expected
    9. Disabling seatbelt reminder chimes.
    Turn off the annoying "Bing bong" when you move the car on the driveway without your seatbelt fastened.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Click on byte 0 and in bit 4 you'll see the selectable option: "Seat Belt Warning inactive"
    Check this option
    [Do It!]
    Thanks to Mr Fish for finding and posting this up.
    10. Disabling engine stop when opening driver's door.
    Recode the Central Convenience module to STOP the engine from turning off when you get out, having moved the car.
    [Select]
    [46 - Central Conv.]
    [Coding - 07]
    Click on the red byte (below) and in the binary code you will see: 00000111
    Change it to: 00001111
    ie. with 1111 at the end not 111
    Tab into the next bit box and you will see the code change to 0F (013F062220B9000083200904200104070000000000000000000000000000 to 013B062220B90000832009042001040F0000000000000000000000000000)
    [close the long code helper]
    [Do It!]
    Good luck if you try these changes yourself! If you know of any other tricks, please add them to the thread.
    MF.
    Last edited by MFGF; 08-05-2013 at 11:00 AM. Reason: Added technique to disable engine stop on opening driver's door
    MY2012 A6 Saloon 2.0TDi S line - Ice Silver, Tech Pack, DAB, Storage Pack, Lighting Pack, Heated F+R Seats, 4 zone A/C, 75l Tank, 20" Rotors, Boot Liner, Umbrella Brackets. VCDS mods: Needle sweep, VIM, Beep on lock, Hidden Menu, Kerb lighting, Mirror Dip on Reverse.
    A6 figure salary, A6 pack, A6. One out of three is a start!
    Got an A6 TDi? Join the A6 TDi Club! Got an A6 Le Mans? Join the A6 Le Mans Club!
  2. Thanks 5678, shabazmo thanked for this post
  3. The Following 2 Users Say Thank You to MFGF For This Useful Post:
    5678 (30-04-2012), shabazmo (28-04-2012)
  4. #2
    Mar 2012
    Berkshire
    12
    Re: A6 C7 VCDS Tricks
    Very keen to follow this thread and see what else is posted.
    Slight tangent, but do you know if the VCDS software is available for OSX?
  5. #3
    Nov 2009
    N.Ireland
    864
    Quote Originally Posted by 5678 View Post
    I believe you can use Bootcamp or Paralells to create a Windows VM and then run vcds off that.
  6. #4
    Mar 2012
    Berkshire
    12
    Thanks Chris. Thought this may be the case.
  7. #5
    May 2009
    225
    Yep - that is the way to go. VCDS is not supported natively on a Mac. See FAQ 1.8 on the Ross Tech support site, here:
    http://www.ross-tech.com/vag-com/faq_1.html
    Cheers!
    MF.
    Snet form my fumblefingers
    iPhon 5 usig Tapatalk
  8. #6
    Aug 2007
    Hook Hampshire
    9
    I tried the kerb lighting but no success. I assume that the lighting switch should be set at automatic.
    3. Kerb lighting
    [Select]
    [09-Cent. Elect.]
    [Do It!]
    Audi A7 Dakota Grey, 3.0TDi 2wd, engine CLAB, Gearbox NKP, Comfort seats, parking system advance, advance key, MMI Nav plus, MMI touch, HUD, Mob phone prep high with on-line services, heated sports steering wheel, folding mirrors, garage opener, fine grain ash inlays. 35k miles
    My Wife's Ford Galaxy Ghia X 1998 1.9TDI 220K miles, AFN engine, atlantic blue, purchased new.
    Mum's VW Polo 1.6GL 1997, AEE engine gragon green, 60,000 miles
  9. #7
    May 2009
    225
    Quote Originally Posted by shabazmo View Post
    3. Kerb lighting
    [Select]
    [09-Cent. Elect.]
    [Do It!]
    I haven't driven in the dark to be able to test it. Mine may well not work either. I will report back when I get the opportunity to test...
    MF.
    Sent from my iPad using Tapatalk HD
  10. #8
    May 2009
    225
    3. Kerb lighting
    [Select]
    [09-Cent. Elect.]
    [Do It!]
    I finally tried this tonight. With the switch on Auto, I saw the lighting pattern change as I turned sharp right before reversing into my drive. I kept my eye on the extra pool of light as I straightened the wheel, and saw it go again - it faded down rather than just cutting off suddenly. My car does not have AFS headlights, so it can only have been the all-weather light fading up and down for the sharp cornering manoeuvre. It only operates at low speeds I think.
    Cheers!
    MF.
  11. #9
    Aug 2007
    Hook Hampshire
    9
    I concur, it does work. When i first tried it, I don't know why it did not work, but it does now. Not sure about the extra benefit though, I have xenons, so did not notice much diference, but early days yet. will give an update later.
  12. #10
    Feb 2012
    Epsom UK
    29
    Is it possible to extend how long the ACC stays in Automatic Go?
    If you have tried to use MyAudi, please look here.
  1. Audi A4 B8 - VAG.com Tricks
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 -
    Last Post: 09-03-2013, 05:01 PM
  2. mark 5 tips and tricks
    By m24man786 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2010, 08:58 AM
  3. Audi A6 Tricks ??????????????
    By slice636 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2009, 11:27 AM
  4. Question vag com tricks?
    By andymartin045 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2009, 07:43 PM
  5. tips and tricks for golf mk5's
    By Ben in forum Golf MK5 - 2004 - 2009
    Last Post: 17-08-2008, 09:25 PM
Back to top
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Copyright: VW Audi Forum is an AUTHORISED DEALER for the Surf City Garage range of car care products. All Surf City Garage images are "Copyright" of Surf City Garage
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
- www.vwaudiforum.co.uk - www.vwaf.co.uk - www.vwaf.co.uk - www.vwaudiforum.co.uk -
/p
