Thread: Audi AUX
Results 1 to 10 of 20
  1. Smile Audi AUX
    Feb 2012
    Bolton
    Hi Guys
    Just replaced my radio as concert was skipping and only 2 gb cards so i thiought sack it get another one which cost me in total of 200 quid. Now its in all working fine but in media i get the AMI option even though its not installed yet but no AUX option. Is there any way to enable this so i can use this??
    2008 Audi A4 2.0 TDi 143 Se, Black, 6 Speed Manual, 17 Inch Alloys
  2. Re: Audi AUX
    46 Post(s)
    You will have to get someone to change the coding of the radio to suit your car.
    You can add AMI (I think) if the headunit has a Media button
  3. Re: Audi AUX
    Feb 2012
    Bolton
    HI
    The AMI option is there. I just need the AUX option. Any idea what needs changing
  4. Re: Audi AUX
    46 Post(s)
    I'll go and have a look online
  5. Re: Audi AUX
    Feb 2012
    Bolton
    Thanks Chris
  6. Re: Audi AUX
    Oct 2010
    Huddersfield
    As above, it's just a case of coding the car to tell it you don't have the AMI, but do have the Aux, Probably a 5min job for someone with Vag-com and the knowledge of where to find it.
    If you have no luck, try contacting craig b in Manchester here: http://www.tclsatnav.com/
    He has fitted all my audio and AMI equipment for me, and would know exactly what to do, if you can't find someone nearby to do it for free.
  7. Re: Audi AUX
    Feb 2012
    Bolton
    Vag-COM cable is not a problem.. I just need to know what to do when in there.. What needs chaging to get this working
    46 Post(s)
    I had a look earlier online and it looks like the 56 - Radio module goes by long coding so it should just be as easy ticking and unticking the relevant box to match the equipment fitted.
  9. Re: Audi AUX
    Feb 2012
    Bolton
    thanks for the help
    I have tried this and in vag com ticked the aux installed but still this does not show when pressing the media button???
    Is there anything else or would i have to disable one to get the other??
  10. Re: Audi AUX
    46 Post(s)
    Press media, then one of the inner keys should relate to source on the screen.
    Did you reboot the radio after making the changes?
    Im not sure how its done on the Concert though. It (should) say in your radio manual but I'll go off and look online.
    Okay - This may work and it may not but hold in SETUP, central dial and the top right inner key and (hopefully) the radio should reboot.
  1. How To Audi concert Aux in through CD changer, but can’t select Changer on head why?
    By eddie_baby in forum In Car Entertainment
    Last Post: 13-06-2012, 05:47 PM
  2. Audi A3 Nav System and Aux?
    By hinfinity in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-03-2010, 08:58 PM
  3. AUX line out AUDI A6 2005 MMI BASIC non BOSE audio system
    By Bretsinclair in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-02-2010, 05:32 PM
  4. Aux In
    By youdanavich in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2008, 08:14 AM
  5. 2000 audi A4 1.8T quattro avant aux cooling fan
    By bobbakall in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-11-2007, 05:59 AM
