Thread: ESP light on 01314 and 17656 codes
  1. Question ESP light on 01314 and 17656 codes
    Sep 2011
    Hastings
    Hello
    I recently changed my timing belt on my Audi A3 1.9TDI 2001 and straight after that received a problem
    The car itself drives without any problems. Only thing bothering me is, after driving the car for about 5 minutes the ESP light comes on ABS light doesnt, the actual abs does work although ESP doesnt. as in i can spin wheels all i want -.- but if i turn off the engine and start it again for 5 minutes the ESP works and i can turn it off and on using button but then when the light comes on it doesnt work.
    Now i checked it using VCDS tool and i got the error
    VCDS-Lite Version: Release 1.0
    Sunday, 29 January 2012, 18:52:53.
    Control Module Part Number: 1C0 907 379 E
    Component and/or Version: ESP FRONT MK60 0104
    Software Coding: 0019458
    Work Shop Code: WSC 06435
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    I have researched the internet and found out that all this says is run error test in engine bit so i did ( Do correct me if i am wrong about this code 01314)
    In engine bit i got this code
    Tuesday, 31 January 2012, 22:09:05.
    Control Module Part Number: 038 906 012 BB
    Component and/or Version: 1,9l R4 EDC 0000SG 2809
    Software Coding: 00002
    1 Fault Found:
    17656 - Start of Injection Timing Regulation: Control Deviation
    P1248 - 35-10 - - - Intermittent
    Now i dont quite get this second fault. Are they related or not?
    I have read about this code on Ross-Tech website and it says it apears when there is a power loss when driving fast. i did have that before the cam belt change but it did kinda disapear for the past few weeks or i havent driven that fast for pas weeks. I have never had this light come on before.
    Could someone explain these two faults PLEASE
  2. Re: ESP light on 01314 and 17656 codes
    Jan 2009
    towcester northants
    you havnt set the commencement of injection up!
    common fault!
    people do there cambelts and dont do them properly!
    on the earlier engines with the ve pump you need to set the pump timing up using vcds
    what engine code is it?
  3. Re: ESP light on 01314 and 17656 codes
    Jun 2012
    spalding
    Quote Originally Posted by A3DS3 View Post
    Hello
    1 Fault Found:
    1 Fault Found:
    how do you fix the problem my skoda octavia has the same issue with the code 01314 with the esp light but car drives fine why does this happen?
  4. Re: ESP light on 01314 and 17656 codes
    Jan 2009
    towcester northants
    your second fault says to me that this engine is a seperate pump tdi?
    if this is the case then you havnt got the pump timing correct
    you need to set the pump timing up dynamically
  1. audi 53 plate esp light on abs light on handbrake light flashing
    By craigq in forum Chat - Anything with wheels
    Last Post: 03-09-2011, 08:58 PM
  2. Non Starter - VAG Code 01314
    By hapz1 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2010, 10:53 PM
  3. interittent esp light fault codes 18265 and 00526
    By nickeym1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-02-2010, 10:28 PM
  4. ESP / EPC fault codes advice.
    By mickk in forum VCDS - General Questions
    Last Post: 15-02-2010, 11:10 AM
  5. Please Help ESP off light - codes - which parts?
    By munchkincoupe in forum Golf MK5 - 2004 - 2009
    Last Post: 06-01-2010, 10:01 PM
