Thread: Cleaning a Breather / Recycling Pipe
  1. Cleaning a Breather / Recycling Pipe
    Jan 2012
    Hemel Hempstead
    Sensor and Breather Pipe
    Hi All,
    The Engine Management Light on my Audi A2 1.4 petrol has come on again.
    Last time this happened I had the throttle cleaned and a breather pipe cleaned out.
    I have just cleaned the throttle myself but that hasn't cleared the light.
    However the pipe that comes up the back of the engine and joins the air intake box attached to the throttle feels as if it is full of gunk. Also on that pipe is a sensor. I think this is the MAP sensor. This is very hot, whilst the pipe is not. Shorting out the sensor does clear the Engine Management Light.
    Removing the pipe or the sensor for cleaning looks an imposible task due to access. Has anyone done this?
    Moderator edit - Moved from 'How To' section
  2. Re: Cleaning a Breather / Recycling Pipe
    boustie Guest
    sounds unlikely what are the fault codes, also throttle will need basic setting after youve cleaned it or it will run exactly the same as before you cleaned it
  3. Re: Cleaning a Breather / Recycling Pipe
    Nov 2009
    46 Post(s)
    im sure after 1 year its been sorted ...
  4. Re: Cleaning a Breather / Recycling Pipe
    boustie Guest
    You never know !,
  1. Broken Breather Pipe
    By vdubm0d in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-03-2023, 12:50 PM
  2. oil breather pipe
    By raymondbilko in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-03-2011, 10:48 AM
  3. Please Help Cleaning out Oil Breather Pipe
    By MAF72 in forum Golf MK3 - 1993 - 1999
    Last Post: 02-07-2010, 04:59 PM
  4. Question Oil Up Breather pipe..
    By avantscott in forum The Commercial Range
    Last Post: 12-08-2009, 03:56 PM
  5. Blocked breather pipe
    By carey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-12-2008, 09:21 PM
