Thread: Service Reset Indicator - A4 B8 2008 - Can't reset Service Due message
  1. Service Reset Indicator - A4 B8 2008 - Can't reset Service Due message
    Oct 2011
    Darlington
    Looking for some help with resetting warning in DIS/MMI. I used the SRI option (Flexible Oil Service Reset - Long Life - GB - Diesel) on Vag-com 10.6.4 (Current value was 1 on channel 02). The programme showed new value as 0. Routine ran and the code was set to 0, however, in the MMI screen it still shows the Service Due counter (currently 900miles ago !! and climbing). I ran the routing again via control module 17 Instruments and tried to change channel 02, stored value 1 (Yes it reverted back to 1) to 0. Test and Save performed, value set to 0, but still showing in MMI and DIS screen.
    All other value were changes (Distance and Time to oil change). The car is set to variable service on a 143 TDI SE.
    Help much appreciated.
    Mike
  2. Re: Service Reset Indicator - A4 B8 2008 - Can't reset Service Due message
    Jan 2009
    towcester northants
    you need to adjust channels 50-52 manually
  3. Re: Service Reset Indicator - A4 B8 2008 - Can't reset Service Due message
    Oct 2011
    Darlington
    Thanks for the reply. Do you know what figures I should enter into these channels?
    Channel 50 - Basic Distance Value for oil change - Current value = 145 (x100km)
    Channel 51 - Basic Time Value for oil change - Current value = 365days
    Channel 52 - Basic Distance Value for inspection - Current value = 300 (x100km)
    These were set by the SRI function. Do I have to go in via the Instruments option ?
    Mike
  4. Re: Service Reset Indicator - A4 B8 2008 - Can't reset Service Due message
    Jan 2009
    towcester northants
    go in via instruments
    check all listed parameters in adaption channels from 40 upwards
    you will see which one reqs adjustment and it will change on the dash display to confirm
  5. Re: Service Reset Indicator - A4 B8 2008 - Can't reset Service Due message
    Dec 2007
    Hi mike did you manage to reset the service light and if so how did you do it please?
    Dave
  6. Re: Service Reset Indicator - A4 B8 2008 - Can't reset Service Due message
    Oct 2011
    Darlington
    No luck I'm afraid. The car is in an Audi independant today and I've asked them to reset the service light. I'll quiz them on how they did it. Will let you know how I get on.
    Mike
  7. Re: Service Reset Indicator - A4 B8 2008 - Can't reset Service Due message
    Oct 2011
    Darlington
    Service reminder finally reset. The garage reset the car to pdi (pre delivery inspection) and then reset service through Sri (service reset indicator) option in Vagcom.
    Hope that helps.
    Mike
  8. Re: Service Reset Indicator - A4 B8 2008 - Can't reset Service Due message
    Dec 2007
    Just done a 2008 A3 and reset fields 53 and 55 to zero and all seems to be well so hopefully this is what is required. I hope this works for all and any feedback welcome
    Dave
  9. Re: Service Reset Indicator - A4 B8 2008 - Can't reset Service Due message
    Apr 2007
    I have 2008 new shape Audi A4 Tdi. the service Due wont go away with normal VAG tools.
    I have original VAG and since I updated the software from ROSS it has now got service reset in the service options.
    In service options you cant select individul channels like 50 or 52 or 53. its all done for you.
    I just select the service reset ( time or mileage) then hit reset and it reprograms all those boxes in the car and service due goes away.
    Done mine and been driving for a month now, no problems.
    my email is: walkonwater80@hotmail.com. will be glad to help anyone with any questions.
  1. 2008 A6 service reset
    By thomas m in forum VCDS - Help Requests
    Last Post: 22-10-2009, 11:54 PM
  2. Please Help Service Warning Message Reset
    By -chris- in forum Golf MK4 - 1999 - 2004
    Last Post: 17-03-2009, 01:46 PM
  3. [Lupo] Oil service message reset
    By martain87 in forum Polo - Derby - Lupo - Fox
    Last Post: 24-12-2008, 07:47 PM
  4. MMI Service Message Reset
    By galaxie in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 02-12-2008, 06:58 PM
  5. reset service message-vag com
    By med roberts in forum VCDS - General Questions
    Last Post: 21-05-2008, 12:55 PM
