Thread: Nearside parking lights turning on by themselves and won't switch off
Results 1 to 10 of 11
  1. Angry Nearside parking lights turning on by themselves and won't switch off
    Feb 2010
    England
    Hi Folks
    I'm back in a B6 (my third) after a three year hiatus in a B5. Previously I had a 2001 1.8T quattro Sport and then a 2003 S4. The latest is a 2001 2.5TDI quattro Sport.
    I've had the car just over a month and I'm experiencing a frustrating and annoying problem I've not encountered before in five previous Audis. Periodically, the nearside parking lights turn on by themselves and cannot be switched off by any means. This occurs randomly, and without anything obviously triggering it. It happens after I've driven the car with the lights on and without, and on a number of occasions the lights have turned on all by themselves during the day or night, leaving me with no option but to disconnect the battery in order to avoid draining it. Usually, doing so kills the light only for it to return again randomly sometime later after re-connecting. It will also re-ignite straight away if I re-connect the battery shortly afterwards, but not always. The problem has disappeared once or twice for several days in a row, and then re-occurred daily over the following few days - there's no pattern to it.
    The parking lights work perfectly normally in isolation, with the buzzer sounding when it should (stalk down or up with key out). Equally, the lights themselves all work as they should and there are no other obvious electrical anomalies.
    I had the car scanned for DTCs at ADI and it showed the following:
    http://wiki.ross-tech.com/wiki/index.php/01561
    http://wiki.ross-tech.com/wiki/index.php/01562
    http://wiki.ross-tech.com/wiki/index.php/01134
    The guy who scanned the car felt that these codes weren't necessarily related to the problem with the lights, and as I hadn't had the car long I had no way of knowing if these were old stored faults. They were cleared but unfortunately I don't have easy access to VCDS so I don't know if they've since re-appeared. All the doors and the boot lock and unlock normally as I would expect them to. There's no water in the plenum chamber and no damp passenger footwell carpet, so no obvious signs of CCM water ingress.
    When I first noticed this problem and realised that all attempts to turn off the lights were futile, I removed the rear light cluster and pulled the bulbs. As soon as I did so the offside tail light lit up instead, together with the offside front side light which also came on in addition to the nearside one already lit.
    All my Audi-owning friends are stumped (including past and present B6 owners), so I'd be very grateful to anyone who may be able to shed any light(!) on this or offer any suggestions as to a solution. This is spoiling what is otherwise a very good car.
    Any B6 owners out there had this problem? Thanks.
    B6 A4 2.5TDI quattro Sport (AKE)
  2. Re: Nearside parking lights turning on by themselves and won't switch off
    Southern County Softy
    20 Post(s)
    Hello John, good to see you posting.
    Could it be a problem with the wiper stalk ?
    Might be worth giving it a squirt with some contact cleaner, also check all bulbs making sure the are the correct bulbs and have clean contacts.
    A4 2.5 tdi QS (mapped)
  3. Re: Nearside parking lights turning on by themselves and won't switch off
    chester
    17 Post(s)
    Electrical gremlins,nightmare!Got a towbar fitted,or any evidence of fitting.
  4. Re: Nearside parking lights turning on by themselves and won't switch off
    Feb 2010
    England
    Thanks George! Will check the bulbs and contacts etc. No, no towbar has ever been fitted.
  5. Re: Nearside parking lights turning on by themselves and won't switch off
    Feb 2010
    England
    Thanks to rain I haven't had the opportunity to check any of the bulbs yet. However, since Sunday evening the offside sidelights are now sticking on too. Last night I disconnected the battery as usual, left it for a while and then reconnected it later when I had to retrieve something from the boot. At first no lights came on so I locked up and left it, but an hour or so later when I checked again the nearside rear sidelight was on and BOTH front sidelights.
    This morning when I reconnected the battery nothing came on, but by the time I'd got to work all four sidelights were on.
    One thing perhaps worth mentioning is that if I lock the car from the inside using the fob and then trigger the alarm by moving about inside, the hazards flash as expected but there is no alarm sound. I only discovered this last night. I wonder if this could be related to or a symptom of the sidelight problem?
  6. Re: Nearside parking lights turning on by themselves and won't switch off
    20 Post(s)
    could be the alarm siren is broke...not uncommon, also could be a sign that the plenum chamber has flooded at some time in the past.
    You can test the alarm horn with VCDS, there is a "how to" here regarding fixing the leaky batteries inside the alarm....
  1. Parking brake switch
    By sparkyrjp in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-03-2011, 12:22 PM
  2. Question Nearside mirror dips to assist reverse parking
    By ron19 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-12-2010, 05:54 PM
  3. Please Help Engine not turning off and lights flashing on the dash
    By sadaqt in forum Golf MK3 - 1993 - 1999
    Last Post: 14-09-2010, 11:22 PM
  4. '97 Passat lights not turning off
    By ImolaOrange in forum Archive posts
    Last Post: 30-01-2007, 10:46 AM
  5. Noise from turning lights on
    By andrew00011 in forum Audi A4 - Archive Topics
    Last Post: 24-01-2007, 02:14 PM
