Thread: Console Bushes
  1. Console Bushes
    Mar 2010
    High Wycombe UK
    6
    My 56 plate 2.0TDI Sport SE estate is just in for routine (oil and pollen filter) service at 64K miles. Call from dealer saying front console bushes are split and need replacing. Cost 450 incl VAT. I bought car used from this dealer in March 2010 with 33K miles on it and a one yeaer VW used vehicle warranty. Car has full VW service history so far but this is a lot of money to pay out. :-( I understand that the console bushes are relatively inexpensive compared to the fitted cost and reading other posts I see that Powerflex bushes are better. I am a reasonably competent mechanic with a pretty full range of tools. Questions: 1) How difficult it is to replace these bushes, 2) Where might I find instructions? 3) I have seen that disturbed nuts and bolts must be replaced - is this correct?
    Thanks very much.
  2. Re: Console Bushes
    197
    Yes the fasteners must be replaced. From VW the bush comes as a complete bracket 3C0 199 231 D at 53.47 each.
    http://www.candrenterprises.co.uk/sh...h-vw-06-1.html
    http://www.candrenterprises.co.uk/shop/superpro-uprated-suspension-bushes-vw-2005-2010-6.html
    The mount is easy to remove but really you should use an alignment pin, VW tool T10096 so maintaining the suspension alignment.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
    www.helpforheroes.org.uk
    Keep XH558 in the air
    www.vulcantothesky.org
  3. Thanks g-black thanked for this post
  4. The Following User Says Thank You to Crasher For This Useful Post:
    g-black (19-09-2011)
  5. Re: Console Bushes
    Mar 2010
    High Wycombe UK
    6
    Thank-you Crasher for this helpful information. I found the T10096 pins at Laser tools but it is for a set of 4. This perhaps suggests that the whole subframe needs to be loosened when changing the bushes? Or are the bolts holding the console bush bracket the same ones that hold the subframe in place in that corner? Is the T10096 pin left in place when the job is finished or do you remove it? Thanks. I'm basically trying to make sure I don't get into a job I can't finish properly and trying to work out how difficult it is and what the bits will cost me. Do you know if the VW console bush price includes the replacement bolts?The VW dealer told me they have 2.2 hrs time chargeable for the job but rarely get it done in less than 3 hours.
  6. Re: Console Bushes
    197
    You need a set of four pins IF you are dropping the whole subframe down, only one for a single consul removal. You insert the T10096, tighten it up and then remove the other two bolts, the bush aligns itself in the consuls bolt hole which can be perfectly aligned with the thread or offset to a degree, this means that when you put the consul back, it is fitted in the same place as it was originally. The VAG price is consul only, it is not a kit. I can do one consul in less than an hour if using a new standard consul, removing a VW bush and fitting a Powerflex adds quite a lot of time cutting the old bush out but fitting the new Powerflex is very easy, the Superpro is a little more involved as it is steel sleeved.
  7. Re: Console Bushes
    Mar 2010
    High Wycombe UK
    6
    Thanks Crasher. Does your business also supply the T10096 pins? It seems I would only need 1 to do the bushes one side at a time. or I guess I could make one from an M12 bolt with the head suitably tapered and with a smaller hex welded on to screw it in?
  8. Re: Console Bushes
    197
    You can order VAG tools from here tools.equipment@vwg.co.uk
  1. rubber console bushes
    By shahid1973 in forum Bora - 1998 - 2005
    Last Post: 27-02-2011, 01:12 AM
  2. How To centre console
    By passat tdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-01-2011, 07:14 PM
  3. 47K "Console bushes"
    By simonarius in forum Golf MK5 - 2004 - 2009
    Last Post: 28-08-2008, 09:51 PM
  4. centre console
    By sbt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-07-2008, 08:43 PM
  5. Question centre console
    By tam64 in forum Golf MK3 - 1993 - 1999
    Last Post: 02-06-2008, 10:06 AM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
