Thread: 1.9tdi which engine oil to use - confused
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: 1.9tdi which engine oil to use - confused
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    It's the same across most "production" these days.....it will even be the same at the component level inside the electronics....
  2. Re: 1.9tdi which engine oil to use - confused
    Jan 2014
    Glossop
    If that is the case, why did the 205 litre barrel of Quantum Platinum I have just opened say BP on the label?
    Just joined and saw this post whilst searching. Its probably say BP as both BP and Castrol are Burmah Castrol.Follow link below. Worked for Castrol years ago and pensions are through BP, same company, different labels.
    http://www.bp.com/en/global/corporat...and+lubricants
    Also notice that the Ford formula f oil is in the same bottle as Quantum oils and the Ford stuff is Castrol, says so on the label, lubricants UK who are BP/Castrol
  3. Re: 1.9tdi which engine oil to use - confused
    1840 Post(s)
    The new drum I have just had delivered says BP Europa Belgium on it.
  1. Confused about oil changes when buying used
    By SteveE in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-03-2010, 10:30 PM
  2. Replies: 3
    Last Post: 23-02-2010, 06:38 PM
  3. T4 1.9TDI Engine oil
    By dangerousdog in forum The Commercial Range
    Last Post: 22-10-2008, 12:04 PM
  4. Golf Match 1.9tdi - Engine Oil Change
    By oriondirect in forum Golf MK5 - 2004 - 2009
    Last Post: 18-06-2008, 09:12 PM
  5. engine oil for transporter t5 t28 1.9tdi
    By paul600rr in forum Archive posts
    Last Post: 26-12-2007, 04:16 PM
