Thread: Dipping door mirror on reverse
  1. Question Dipping door mirror on reverse
    Mar 2009
    Helsingborg, Sweden
    I'm pretty sure this has come up before but I can't find the info
    I've come to terms with the door mirrors not folding automatically but I thought it should be possible for the passenger door mirror to angle down when reversing, assuming that the control knob is positioned to that mirror.
    Can anyone shed some light on this please ?
    Cheers in advance
  2. Re: Dipping door mirror on reverse
    46 Post(s)
    I think you need electric seats to enable it. I cant seem to find it in VCDS for my 2008 saloon but on the 2011 Q5 I had on loan, the long coding provided the tickbox to enable it.
  3. Re: Dipping door mirror on reverse
    Mar 2009
    Helsingborg, Sweden
    Maybe thats what I've seen before, although I felt sure someone had found a way around the electric memory seats. It just seems strange when the mirrors are electrically manoeuvrable! Thanks for the input though
  4. Re: Dipping door mirror on reverse
    Apr 2009
    Can be done without memory seats.
    In VCDS go to the Module 52 Passenger Door. In Coding, if you see long coding you can set it, if you see short coding then you can't.
    Assuming you see long coding, use the long code helper and change byte 4 from 40 (non folding mirror) to 4C.
    works a treat, although the mirror only seems to tilt back up when switching the mirror knob back to centre. It doesn't tilt back just by taking it out of reverse.
    Hope that helps
    Current: 2012 Q7 S-Line
    Previous: 2011 A6 Avant 2.0TDi S-Line Special Edition; 2007 Q7 3.0TDi Quattro S-Line; 2006 A6 3.0TDi Quattro S-Line Le Mans; 2005 A6 2.0TDi SE
  5. Re: Dipping door mirror on reverse
    Mar 2009
    Helsingborg, Sweden
    Hi.
    mmmm interesting. I'm not so good with the VCDS gizmo but I'll give it a whirl and see what happens. Thanks for the info
    2012 VW CC 2.0 TDi
  1. Dipping door mirrors?
    By nick41 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-01-2010, 04:08 PM
  2. Auto Dipping passenger side door mirror
    By DAVID5416 in forum Golf MK6 - 2009 - 2013
    Last Post: 17-10-2009, 01:54 PM
  3. Question Trouble with door mirror dipping on selecting reverse
    By bigpeter in forum Jetta MK3 - 2005 - 2013
    Last Post: 27-01-2009, 12:50 PM
  4. Self-dipping rearview mirror/audi control steering wheel
    By adowds in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-08-2008, 08:16 PM
  5. kerb dipping mirror
    By Will_Touran in forum Touran - Sharan - Caravelle
    Last Post: 11-01-2008, 10:59 PM
