Thread: Fault code
  1. Fault code
    Aug 2009
    Buckshaw Village
    05522.....altitude/boost*pressure*sensor*implausable*correlation*and* intermittent*
    Light came on again 4 days ago but only the 1 time. Took it to the garage today and the mechanic said it's nothing to worry about, he test drove it and said everything appears fine.
    What'd reckon guys?
    2013(63) A3 Sportback. 2.0 tdi. 150. Ice Silver. Rear parking. Cruise.
  2. Re: Fault code
    Aug 2009
    Buckshaw Village
    Light back on again this morning and nothing since. Is it normal for this fault to only give one warning then nothing further or is this a sign that tells me not to worry for the time being and if it gets worse it'll tell me? CONFUSED!
  3. Re: Fault code
    1837 Post(s)
    18000 (P1592) 005522 - Altitude Sensor / Boost Pressure Sensor: Implausible Correlation
    Possible Symptoms
    • Malfunction Indicator Light (MIL) active
    • Limp Mode active
    Possible Causes
    • Wiring from/to Boost Pressure Sensor (G31) faulty
    • Ground Spots corroded
    • Boost Pressure Sensor (G31) faulty
    Possible Solutions
    • Check Wiring from/to Boost Pressure Sensor (G31)
    • Check Ground Spots for Corrosion
    • Check Boost Pressure Sensor (G31)
    Special Notes
    • When found in 2.0l TDI-PPD (BMN), check TSB/TPL's first.
      • Possible Causes: Software Issue, High Resistance in Engine Wiring Harness, Ground Spots corroded
      • Possible Solutions: Check/Update Engine Control Module Software, Check Wiring from/to Boost Pressure Sensor (G31), Check Ground Spots for Corrosion
  4. Re: Fault code
    Aug 2009
    Buckshaw Village
    Crasher- any idea of the cost of a new sensor? Lights coming on more frequent now and I'm guessing the most expensive scenario would be to replace the sensor, cheers.
  5. Re: Fault code
    1837 Post(s)
    The sensor is about £45 and on the boost pipe in the engine bay just before the pipe turns into the flap motor, a bit awkward to get at.
  6. Re: Fault code
    Aug 2009
    Buckshaw Village
    Pulling my freeking hair out with local garages! Asked the latest one to replace the boost sensor for me and he said it's probably a leak in the turbo system! And they're supposed to be vw experts.
    Ended up ringing VW Preston up and they've told me it's a common fault and either the wireing loom needs replaceing or a new sensor fitted, more than likely the wiring loom though and will be cost of part + 2 hrs labour (£60 per hr)
    hopefully get sorted now :-(
  1. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  2. VAGCOM Fault Code 00588 - Airbag fault
    By headache56 in forum VCDS - General Questions
    Last Post: 31-01-2009, 01:05 PM
  3. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    Last Post: 16-01-2009, 06:05 PM
  4. ABS Fault, have fault code readout....
    By nemeth782 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-08-2008, 12:15 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
