Thread: Fault code
  1. Fault code
    Aug 2009
    Buckshaw Village
    24
    05522.....altitude/boost*pressure*sensor*implausable*correlation*and* intermittent*
    Light came on again 4 days ago but only the 1 time. Took it to the garage today and the mechanic said it's nothing to worry about, he test drove it and said everything appears fine.
    What'd reckon guys?
    2013(63) A3 Sportback. 2.0 tdi. 150. Ice Silver. Rear parking. Cruise.
  2. Re: Fault code
    Aug 2009
    Buckshaw Village
    24
    Light back on again this morning and nothing since. Is it normal for this fault to only give one warning then nothing further or is this a sign that tells me not to worry for the time being and if it gets worse it'll tell me? CONFUSED!
  3. Re: Fault code
    197
    18000 (P1592) 005522 - Altitude Sensor / Boost Pressure Sensor: Implausible Correlation
    Possible Symptoms
    • Malfunction Indicator Light (MIL) active
    • Limp Mode active
    Possible Causes
    • Wiring from/to Boost Pressure Sensor (G31) faulty
    • Ground Spots corroded
    • Boost Pressure Sensor (G31) faulty
    Possible Solutions
    • Check Wiring from/to Boost Pressure Sensor (G31)
    • Check Ground Spots for Corrosion
    • Check Boost Pressure Sensor (G31)
    Special Notes
    • When found in 2.0l TDI-PPD (BMN), check TSB/TPL's first.
      • Possible Causes: Software Issue, High Resistance in Engine Wiring Harness, Ground Spots corroded
      • Possible Solutions: Check/Update Engine Control Module Software, Check Wiring from/to Boost Pressure Sensor (G31), Check Ground Spots for Corrosion
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
    www.helpforheroes.org.uk
    Keep XH558 in the air
    www.vulcantothesky.org
  4. Thanks Redders2 thanked for this post
  5. The Following User Says Thank You to Crasher For This Useful Post:
    Redders2 (15-07-2011)
  6. Re: Fault code
    Aug 2009
    Buckshaw Village
    24
    Crasher- any idea of the cost of a new sensor? Lights coming on more frequent now and I'm guessing the most expensive scenario would be to replace the sensor, cheers.
  7. Re: Fault code
    197
    The sensor is about 45 and on the boost pipe in the engine bay just before the pipe turns into the flap motor, a bit awkward to get at.
  8. Thanks Redders2 thanked for this post
  9. The Following User Says Thank You to Crasher For This Useful Post:
    Redders2 (17-07-2011)
  10. Re: Fault code
    Aug 2009
    Buckshaw Village
    24
    Pulling my freeking hair out with local garages! Asked the latest one to replace the boost sensor for me and he said it's probably a leak in the turbo system! And they're supposed to be vw experts.
    Ended up ringing VW Preston up and they've told me it's a common fault and either the wireing loom needs replaceing or a new sensor fitted, more than likely the wiring loom though and will be cost of part + 2 hrs labour (60 per hr)
    hopefully get sorted now :-(
  11. Re: Fault code
    Aug 2009
    Buckshaw Village
    24
    Job done, new wiring loom fitted. Best part of 190 :-@
    hope that's the end of it!
  1. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  2. VAGCOM Fault Code 00588 - Airbag fault
    By headache56 in forum VCDS - General Questions
    Last Post: 31-01-2009, 01:05 PM
  3. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
  4. ABS Fault, have fault code readout....
    By nemeth782 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-08-2008, 12:15 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
