Welcome to the VW AUDI Forum - VWAF.
Results 1 to 9 of 9
  1. #1
    Feb 2011
    Winchester
    15
    Intake Manifold Runner adaption
    I've been getting the faults listed later on my 2006 A6 2.7 TDi Avant and diagnosed the bank 2 intake manifold (swirl flap) motor as being faulty (that's the one on the right hand side when you stand in front of the car). You could see that it was not doing the same thing as the other motor. There are some good forum entries which have helped a lot in diagnosis.
    Found a new motor on eBay, without the flaps. £95, brand new, bargain.
    Part number 059129086
    I have read on the Ross-Tech wiki that I need to adapt the new motor when I replace it. Motor hasn't arrived yet so tonight I thought I'd just try the adaption instructions using vagcom from the Ross-Tech website which says that it's group 142, in the basic setting of the engine controller. That group is not found, which made me wonder if there is one group number for bank 1 and another for bank 2?
    Anyone done this before, it seems like a fairly common fault.
    <info>
    012597 - Intake Manifold Runner Control: Lower Stop not Reached
    P3135 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 15
    Mileage: 217228 km
    Time Indication: 0
    Date: 2011.06.10
    Time: 18:03:08
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Voltage: 12.24 V
    Duty Cycle: 88.8 %
    Duty Cycle: 20.5 %
    Duty Cycle: 20.5 %
    004120 - Intake Manifold Runner (Bank 2): Lower limit not reached
    P1018 - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 105
    Mileage: 217228 km
    Time Indication: 0
    Date: 2011.06.10
    Time: 18:22:03
    Freeze Frame:
    RPM: 756 /min
    Torque: 39.0 Nm
    Speed: 0.0 km/h
    Voltage: 13.60 V
    Duty Cycle: 80.9 %
    Duty Cycle: 88.8 %
    Duty Cycle: 80.9 %
    Adaption procedure from Ross-Tech
    Prerequisites:
    * Ignition ON
    * Engine OFF
    * System voltage at least 11.0 V.
    [Select]
    [01 - Engine]
    [Basic Settings - 04]
    Group 142
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    Wait until Field 4 shows "ADP. O.K.".
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    * Switch Ignition OFF for at least 60 seconds.
  2. #2
    Aug 2011
    Phoenix, AZ, USA
    Re: Intake Manifold Runner adaption
    I had an intake runner problem at one time, I found it was a cracked vacuum line. Might be something to look into.
    Sam
  3. #3
    197
    059129086 changed to 059 129 711 T then 059 129 71 AG then 059 129 711 AF then 059 129 71 AL then 059 129 711 BP then 059 129 711 BQ and finally (so far this week) to complete unit 059 129 711 CG
    It is an extremely common fault for the V157 and V275 motors to come up on a code read on these engines and normally you need the complete manifold to go with it and this is why you find the motors for sale on fleaBay as people have bought them (059 129 086) and then found they will have to by the complete manifold that comes with the motor, 059 129 711 CG (left) and 712 BL (right) so they end up with two motors and stick on up for sale to cut their loses.
    Check fuse 12 is ok in the main fuse box in the plenum chamber.
    Without the VAG tester VAS 6395/1 it is not possible to carry out the motor test so most people just fit them and hope for the best. Sometimes Group 142 works.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention...metallic monstrosity, bale and bane of our Culture, chief woe of our Commonweal- W. H. Auden
    Please visit my web site http://www.candrenterprises.co.uk/
    http://www.helpforheroes.org.uk
    http://www.britishlegion.org.uk/
    Support our aviation heritage, keep Vulcan XH558 flying! http://www.vulcantothesky.org/
  4. #4
    Feb 2011
    Winchester
    15
    Thanks crasher, thats very helpful. More part numbers I can look for.
    Why do you have to replace the whole unit? What is it about the flaps that breaks or means that just replacing the motor does not clear the fault.
    BTW
    When the motor turned up I plugged it in and it exhibited eactly the same fault as the knackered one. It would do a limit to limit test, when you turned the ignition on, but would not actuate when you were revving above 1250 rpm. I can swap the LH bank swirl flap motor to the RH bank and the fault moves so I know that it's the motor.
    FWIW The ebay seller never communicated with me when I asked for a refund and after a week eBay gave me my money back. They sent me a postage voucher and I sent it back to him.
    Thanks, this is a great forum. Big
  5. #5
    197
    The linkages wear and they do not come with the motor, they only come as the complete assembly. If it was a 1970’s British car you would be able to buy every single part you need individually, that’s progress for you!
  6. #6
    0
    Quote Originally Posted by big View Post
    BTW
    Did you sort this with a complete unit in the end?
  7. #7
    Feb 2011
    Winchester
    15
    No, my current plan - when I get time -is to add 3mm of washers to raise the motor from the engine block. Apparently this takes out the play in the linkage. There was a discussion on the audi sport forum and I thought I'd give that a go. Backup plan is to manufacture new linkages using ball and socket joints available from RS Components.
    Given that I can't complain about the MPG or the smooth running of the engine and the MOT tests have not focussed on dashboard management information lights then the incentive went away.
    Cheers, Rob
  8. #8
    0
    Thanks for the reply! ok ive messed about with this all day..... basically the flaps are the problem and the fix is replace the lot. When you buy the motor & the manifold ive been told by a very good source that they come preset with the parameters set at factory on assembly and therefore"plug and play", however if you only buy the motor they have to have a basic setting performed, according to the V.A.S. basic setting channel 55 sets up the bank 2 motor to its upper and lower limits. i kept getting the same fault with the new motor, however when i put the old unit back on and final controlled it with out the linkage attached it decided to work, on bank 2. switched it to bank 1 and nothing, so in my opinion switching the motors doesn't necesarily prove anything? i then built it back up and with a little bit of pressure levered the motor ball joint by about 2mm upwards, reset the fault log and road tested. All good for now but positive the fault will return soon enough. Gonna change the whole lot to be sure of a fix.
  9. #9
    197
    This is why you see so many new slightly used motors on fleaBay, people think a motor will fix it but then find it won't and they go back for the flaps and find to their horror they come with the motor. With this problem, don't re-invent the wheel. This has been an ongoing issue now for a few years and the known cure is a new complete flap unit.
  1. 004120 - Intake Manifold Runner - need TPI 2016504
    By TheMatador in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-09-2012, 10:16 AM
  2. audi 3.0 diesel intake manifold runner motor problem
    By daniel_3855 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-10-2011, 06:50 PM
  3. Please Help Intake manifold runner control fault
    By A3Quattro in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-05-2011, 10:50 AM
  4. Please Help 004120 - Intake Manifold Runner (Bank 2): Lower limit not reached
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-01-2011, 01:41 PM
  5. Intake manifold runner control basic setting
    By grabread in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2007, 01:02 PM
Back to top
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Copyright: VW Audi Forum is an AUTHORISED DEALER for the Surf City Garage range of car care products. All Surf City Garage images are "Copyright" of Surf City Garage
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
- www.vwaudiforum.co.uk - www.vwaf.co.uk - www.vwaf.co.uk - www.vwaudiforum.co.uk -
/p
