Thread: LT35 Cant get the alternator to move...desparately need to change alternator belt
  1. LT35 Cant get the alternator to move...desparately need to change alternator belt
    Jun 2011
    cotswolds
    R reg LT35, 2.5 sdi mwb...fan belt close to snapping...i took two obvious bolts off the alternator mounting, situated front left and right below alternator thinking that should allow it to pivot, but there was no play in it at all so i was reluctant to start hitting it with hammers to get it to shift in case there was something else stopping it . have i missed a bolt and if so where is it hiding? or should i be trying to take off the tensioner instead as thats the only other moving part i can see...help! thankx
  2. Re: LT35 Cant get the alternator to move...desparately need to change alternator belt
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    You got it ! Try the Tensioner !
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: LT35 Cant get the alternator to move...desparately need to change alternator belt
    Jun 2011
    cotswolds
    cheers, there are 2 bolts holding it in place, do you know if its the lower bolt under the tensioner spring i need to undo? the upper one seems reluctant to move and seems to have tightened the belt so i guess its just for adjusting?
  1. alternator belt change
    By mpk490p in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-03-2010, 03:01 PM
  2. Question POLO 1.9 SDI Twist power loss after change of alternator and fan belt
    By paragkachare in forum Polo - Derby - Lupo - Fox
    Last Post: 07-12-2009, 03:25 PM
  3. Kinda urgent - replacing belt tensioner, alternator pulley, and belt.
    By farmamick in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-03-2009, 05:00 PM
  4. fan/alternator belt change
    By IFFY83 in forum Polo - Derby - Lupo - Fox
    Last Post: 14-03-2009, 09:15 AM
  5. Aux. belt and alternator pulley change/queries
    By dvhttn in forum Passat - Archive Topics
    Last Post: 22-03-2007, 08:29 PM
